12-11-2006, 09:01 PM | #31 | |||
Giddy up.
12-11-2006, 09:22 PM | #32 | |||
Back to Le Frenchy
Now on a slightly more serious note, am I better off just getting the broken valve spring replaced (if that's what it turns out to be) or do I pay the extra and get some HD valve springs put in. Any ideas on cost or if it's even worth it.
12-11-2006, 10:22 PM | #33 | |||
GT-P #0336
Russ, your rims look real good on my car. That was very kind of you to allow Whoosha to sell bits off your car :nutsycuck Krissy.
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST ~Tuned By Bluepower Racing~ |
12-11-2006, 10:35 PM | #34 | ||
You'd be better off getting decent springs. But if you feel like being tight I've got some spare ones here.
12-11-2006, 11:13 PM | #35 | ||||
Back to Le Frenchy
13-11-2006, 12:12 AM | #36 | ||
I'm just trying to render my GT40Ps useless so I don't have the urge to put them on without doing the cam and springs at the same time.
13-11-2006, 04:28 PM | #37 | |||
Back to Le Frenchy
Well it is bad news, very bad news. It would appear that compression is down in cyl 8 and that the piston has decided to call it a day. It looks like i'm up for some serious $$$ now. Worst thing is i've only had the car for 2 months and it is out of its statutory warranty by 5k. I've got an aftermarket warranty on it but that only covers up to $1k so the rest will have to be forked over by me, that is unless the car yard does the right thing.
13-11-2006, 04:39 PM | #38 | ||
Tickford
Speak to FTG auto salvage (Site sponsor) mate, they have a AU XR8 long motor low km for $2k from memory... I wouldn't bother rebuilding yours unless you went for bigger/better.
I'll buy your block if the bore isn't injured
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD BA XT SZ Territory TS RWD TDCi |
13-11-2006, 04:51 PM | #39 | |||
With da Warlords
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
13-11-2006, 04:55 PM | #40 | |||
not here much anymore
RAM 1500
13-11-2006, 05:06 PM | #41 | |||
Back on the road
My mum drove my car for about 40km's after it broke a valvespring, but she didn't realise it at the time (she rang me to tell my car was idling funny ). The valve was bent from hitting the piston, and was stuck in the guide. A compression test on that cylinder showed up 0psi. The piston was marked but not badly damaged. However it had also killed a rocker, pushrod, and lifter. If your is a similar case, then you really just need to replace the broken bits and reco the heads. OR ditch the GT40p heads, fit some AFR165's, and have the lower intake ported to suit Anyway, hope the bottom end is really OK.
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
13-11-2006, 05:36 PM | #42 | |||
With da Warlords
13-11-2006, 08:51 PM | #43 | |||
Back to Le Frenchy
G&D pulled the head off and have confirmed the worst, the piston in cyl 8 is no more. What kind of a rebuild do you guys reckon I could get for say...5k? Some of you may remember that when I got her there were some issues with the tune of the Unichip, well I did get that tune fixed eventually but obviously the damage had already been done...the cause of this failure is detonation.
13-11-2006, 08:56 PM | #44 | ||
Devastating.... Look on the bright side.. Nows your chance to upgrade ;)
AUIII Falcon Forte, with SIX Appeal |
13-11-2006, 09:02 PM | #45 | ||||
Back to Le Frenchy
13-11-2006, 09:03 PM | #46 | |||
AU DIE HARD
Dam sorry to hear that Russ it still ran preety good for a XR7. that would be the 3rd or 4th XR7 we"ve had now..
as for the mods watch that Matt bloke down there you could end up with a real super charged nitro fired monster and broke for ever : its such a good looking low K car to will be in touch soon .. Whoosha
13-11-2006, 09:12 PM | #47 | |||
If so, i doubt your talking a 5k re-build. You may need a short motor and your heads checked/repaired. The heads on the 220's already have alot more work than most. You do see low km' 220kw motors complete in parts peddler and some good wreckers. Doing this you could be on the road again for less than 5k. You made my heart race, thinking they must have weak Pistons, but detonation will kill any piston...Bad tune=MORE MONEY.. |
13-11-2006, 09:16 PM | #48 | |||
Back to Le Frenchy
I think it's the piston ring hat or something or other that is the issue, top of the piston I believe so not too much damage in there.
13-11-2006, 09:20 PM | #49 | ||
Lucky...in one sence then
13-11-2006, 09:23 PM | #50 | ||||
Back to Le Frenchy
13-11-2006, 09:59 PM | #51 | ||||
Back to Le Frenchy
13-11-2006, 10:42 PM | #52 | ||
Back on the road
Ouch...that sounds nasty. Detonation is a killer.
13-11-2006, 11:07 PM | #53 | |||
14-11-2006, 07:50 PM | #54 | ||||
Back to Le Frenchy
14-11-2006, 09:11 PM | #55 | |||
I'm thinking mine may one day be a 347 LPG stroker (once the kids have left school, in, oh, around 16 years time, LOL).
14-11-2006, 10:09 PM | #56 | ||
Back on the road
I dont think stroking is the best option if you cant afford decent cylinder heads, and ported (lower) intake/or aftermarket intake. IMO, a std stroke 302 with some AFR165's would be a lot more fun than a GT40P headed 331/347.
To be fair though, i haven't driven either combination....so take my advice with a big grain of salt :P
14-11-2006, 10:21 PM | #57 | ||
SS Grunt
Bayford parts on ebay are selling a 5L efi short, including block, cam, crank, rods, pistons and its all new stuff. They are after $1500 thats buy it now.
Shaun
The Beast has gone to a new home Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW I will also enter any part of the Forum I wish to enter. : |
15-11-2006, 07:47 AM | #58 | ||||
Back to Le Frenchy
15-11-2006, 08:28 AM | #59 | |||
BA GT-P Owner
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
15-11-2006, 04:12 PM | #60 | |||
AFF.com.au
Shaun, sell him your engine, made good power on my dyno, send it to cranbourne, get a flasher, bingo fun times |
