Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
29-09-2016, 11:00 AM | #391 | ||
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
And I've been chasing a good condition set for weeks, no joy.
2024 Audi RS 3 Sedan - Mythos Black 2024 Ford Mustang GT - Vapour Blue (built 31-10-2024 - on "TIJUCA" ETA mid-Feb '25) 2023 Skoda Superb Sportline Sedan - Steel Grey |
11-10-2016, 01:35 AM | #392 | ||
http://www.stgeorgetyres.com.au/pack...ct-detail.aspx
I was in the market for staggered 18 inch wheels and... Apparently these 17 inch wheels clear Brembo's? I believe them to be XXR 550's, anyone had any experience with XXR? Last edited by ivanflo; 11-10-2016 at 01:37 AM. Reason: added XXR brand info |
11-10-2016, 09:27 AM | #393 | ||
Matt from Race Brakes Sydney is currently investigating modifying a rotor hub and brackets, so that I can fit Brembo's behind normal wheels. I'll keep you posted on further developments.
11-10-2016, 10:09 AM | #394 | ||
Race Brakes Sydney
The rotor is a two piece option and will run bobbins (which are being manufactured) and just waiting on them to proceed.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
01-01-2017, 09:36 PM | #395 | |||
Kboot 6 - out of interest, how much space do the D1R's have between the wheel and caliper up front over the 4 pots? |
24-02-2017, 02:38 PM | #396 | ||
Would someone know if the following wheels will fit over 6pot brembos?
- Lenso Speed 2 in 19X8.5 Front and 19X9.5 Rear with P35 or P40 offset - XXR 527 in 19X8.75" Front and 19X9.75" Rear with P38 offset I'm going to assume guards will need to be rolled |
25-02-2017, 10:53 AM | #397 | ||
Guys I'm wondering if anyone knows if 19" XR50 Turbo wheels will fit over the 6 pot Brembos? Or anyone in Sydney with 6 pots that I could see if my wheel fits over?
Cheers. |
25-02-2017, 11:45 AM | #398 | ||
50th anniversary rims won't fit over brembos. I had to change rims on my ute when I fitted 4 pot brembos
Current rides 2014 FGX G6E Turbo Tuned by Walter@Oztek performance 504rwkw on e85/420rwkw on 98 with a PCMTec flex fuel tune Previous rides - 2010 FG GT (335 build #152) 437rwkw - 2012 XR6 turbo Ute 345rwkw - 2007 Force 6 (build #91) 330 rwkw - 2010 GTE (build #2) 425rwkw - 2010 50th anniversary turbo ute 365 rwkw |
25-02-2017, 11:41 PM | #399 | ||
Koya SF06...
20x9.5 front +22 clear easily over 6 pots and 20x11 +37 rear just clear rear 4 pots... |
6 users like this post: |
14-03-2017, 07:46 PM | #400 | ||
Can anyone confirm if Vertini Drift 19" x 8.5 +30 fit over 6 Piston brembo brakes? I can confirm that +25 do.
15-03-2017, 12:31 PM | #401 | ||
Race Brakes Sydney
Most suppliers will generally be able to tell you if that helps.
MATTHEW PEARCE
15-03-2017, 12:35 PM | #402 | ||
Thanks for the reply FLOORED. I have tried getting in contact with them but they are unable to confirm if they will fit. But confirm that +25 will
15-03-2017, 01:37 PM | #403 | ||
Race Brakes Sydney
If you have 90mm clearance between the outer rotor face to the inner face of the spoke then they generally fit we don't work off the offset as the spoke can still foul.
MATTHEW PEARCE
15-03-2017, 01:54 PM | #404 | ||
Thanks again FLOORED. Unfortunately It looks like it goes from 93mm to 88mm from the outer side of the spoke down to the hub side.
15-03-2017, 03:53 PM | #405 | ||
Race Brakes Sydney
This may still be enough for you and i would suggest if you can get a Ford with either 4 or 6 front Brembo's on you could check your wheel for clearance.
MATTHEW PEARCE
16-03-2017, 10:02 AM | #406 | ||
06-09-2017, 04:34 AM | #407 | ||
Hi fella's
I recently received Speedy Hotshot wheels from Autocraze (great people to deal with ) The wheels i went for are 19 x 8.5 all around with 245/35/19 rubber on the front and 255/35/19 rubber on the rear.the offset is +30 and they comfortably cleared my 6 spot brembo calipers and discs in front ( i am running standard Ford/FPV brakes in the rear ), the vehicle is a december 2010 FPV GS 315 ute
december 2010 fg gs 315 ute Tuned by Monsta Torque 395.2 KW 610 NM 3.07 diff ratio (changed from original 3.73) 6 spot brembo's on the front 3 inch manta cat back exhaust with X piece 6 speed manual k & n air filter rear calipers painted red debadged stripes etc removed |
30-09-2017, 05:20 PM | #408 | ||
Regular member
20170930_164445 by Gerald Yeo, on Flickr
20170930_164511 by Gerald Yeo, on Flickr 20170930_143634 by Gerald Yeo, on Flickr TSW Nurburgrings in Matte gold. 20 x 8.5 +20 fronts and 20 x 10 +40 rear's. Clear Brembo's with heaps of room!! Thanks Matt!
CURRENT 2013 335 GT - BMC twin filter, Herrod IC, injectors, fuel pump, oil breather, SC pulley and balancer, X-force 2 1/2" cat back with high flow cats = 453rwkw. Thanks to Lee at Real Dyno performance. OLD 2010 FPV F6 FG - Herrod CAI, Pedders extreme XA's, Whiteline fr & rear swaybars, PWR stepped IC, injectors, turbo dump pipe with Venom cat, Herrod piping kit = 350rwkw |
3 users like this post: |
06-10-2017, 12:29 AM | #409 | ||
Inovit Force5 19 x 8.5, P35 offset will also clear brembos:
4 users like this post: |
29-11-2017, 04:14 PM | #410 | ||
Hey all,
Just curious will these rims fit over rear Brembo’s. Thank you in advance Last edited by WyldOne; 29-04-2018 at 10:33 PM. |
29-11-2017, 04:31 PM | #411 | ||
Vertini Hellfire F20x8.5 +30 R20x10 +40
Front will fit 6p not sure about rears, not much room between the caliper to the inside of the wheel. I did ask for these to be cut to suit front brake upgrade. [IMG][/IMG]
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
29-11-2017, 05:31 PM | #412 | ||
Race Brakes Sydney
Being 17" and the dish in them i doubt they will but the manufacture should be able to tell you once they know the model they are being fitted too.
MATTHEW PEARCE
01-12-2017, 09:59 AM | #413 | ||
Thank you mate ☺️
What about 17” Simmons FR with the correct offset. Last edited by WyldOne; 29-04-2018 at 10:33 PM. |
01-12-2017, 11:00 AM | #414 | ||
Race Brakes Sydney
Your best bet is to ask the Simmons supplier which wheels will fit factory FPV brakes as they should have that info. Dished wheels generally wont allow bigger brakes.
MATTHEW PEARCE
14-12-2017, 09:38 PM | #416 | ||
Anyone know if a +40 pos on the rear will clear Brembo’s? Thank you
14-12-2017, 10:12 PM | #417 | ||
BA/F6 BF/F6 SSV/R TTG
Yes, but depends on spoke design.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
14-12-2017, 10:38 PM | #418 | ||
I forgot to add Simmons FR
14-12-2017, 10:54 PM | #419 | ||
Call tempe tyres, they are simmons.
09-03-2018, 05:53 PM | #420 | ||
Anyone know if BF XR6 17” rims clear rear Brembo’s? Thanks
