06-11-2011, 07:12 PM | #301 | ||
Thailand Specials
Having looked under the bonnet and the pictures on the instructions for my cold air intake, it looks like it was designed for an earlier model Focus as mine is different:
Turbodiesel, was that similar to yours? I got my springs and intake in my boot, waiting on the swaybar, links and camber kit to arrive, then waiting on the cooler then I'll take her into the exhaust shop to see what they can do for me. Also, anyone here with an LV XR5/RS, can you post a picture of your airbox/intake, are they the same as the TDCI ones? |
06-11-2011, 08:39 PM | #302 | ||
Torquer
That looks exactly the same as mine Damo, you shouldn't have any problems
2007 LT Focus TDCi S Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero |
06-11-2011, 08:53 PM | #303 | ||
Looks the same as a non turbo one as well, besides where the pipe comes from and the futuristic electronical device attached to it.
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler Plans: Whiteline Rear Sway bar |
06-11-2011, 09:55 PM | #304 | ||
Barra Turbo > V8
Nah XR5 is different, it sits infront of the intake manifold in a box containing the ECU.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
11-11-2011, 08:26 PM | #305 | ||
Thailand Specials
Hey guys, are the Eibach pro kit springs matched to the factory shock absorbers? Apparently you screw your shocks if springs aren't matched?
12-11-2011, 09:26 AM | #306 | ||
I've read that the Eibach springs are match to the factory dampers, but my experience was that after two years, my front shocks were starting to give up, which is how I ended up with matched Koni springs / shocks.
13-11-2011, 10:15 AM | #307 | |||
13-11-2011, 01:24 PM | #308 | ||
Just looked up that Liquid Moly anti knock stuff for diesels. What do you do just tip it in the fuel tank. How long does it work for?
My TDCI smokes a bit under throttle doee it help? |
13-11-2011, 09:51 PM | #309 | |||
Thailand Specials
Interesting, never really thought much of fuel aditives might have to give it a shot. Hopefully all the gear arrives tomorrow at work, then I'll have the springs and everything else put in, she's going in for a wheel alignment afterwards and probably some new decent tyres as well. |
14-11-2011, 11:11 PM | #310 | ||
Torquer
I used Liqui-Moly cetane booster when I went to Marulan, normally my car smokes but watching the video from the car behind it didn't blow out anything.
Could have been because of that or maybe it had already been cleaned out by the constant full throttle. Car was stock then but it went really well.
17-11-2011, 06:00 PM | #311 | ||
Thailand Specials
Got my sway bar, adjustable camber kit and link kit.
How hard is the sway bar to do yourself? Anyone here done it before and any steps to guide me through? Thanks much. |
18-11-2011, 12:12 AM | #312 | ||
Damo, mine was a DIY job. It wasn't too difficult at all. Someone did a great writeup on the XR5 turbo forums, complete with good photos and I found that really helped. I don't have the link bookmarked anymore but a search over on those forums should bring it up.
18-11-2011, 06:25 PM | #313 | ||
Torquer
Larger turbo downpipe and hi-flow cat going on next week!
18-11-2011, 11:46 PM | #314 | |||
Thailand Specials
I noticed my TDCI blows out a big cloud of black smoke under full throttle for a good second, then it stops. It was also running a tad rough at idle today, might be the hot weather, was about 35 degrees idling with the AC on and the needle was hoving up and down near 900 or thereabouts and it was shaking the car every now and again. |
19-11-2011, 10:16 PM | #315 | ||
I have a 2008 6 speed manual TDCi, white.
It blows smoke from 100 kmh to 110 kmh and not much pedal. Possible overfueling but I need to find a diesel shop on the Central Coast who can diagnose it (not e Fraud Stealer). I have replaced both rear calipers and they leaked. Wyong dealer cannot do up the nuts tight either so back for another leak! I had a water leak in the rear hatch that caused a nightmare of mould growth. Dealer said no problems but the nuts on the hatch door had paint taken off them. Why can't they admit there is a problem? Now having a discussion with a Sydney dealer about a rust spot caused by OME bonnet fitting. Dealers!! How does it go? Like someone has stolen it... All the other comments about the torque, the pulling power in 6th, good handling, low consumption (5.5 to 5.8L@100-not by the computer meter) makes it one of the more exciting cars I have driven. I use diesel fuel treatment (in the yellow bottle) and Penrite oil 5-50w and I do services every 8,000 kms not the 10,000 they recommend. Done 28,000 kms now (been away for a while so no driving) ad still happy. Bill |
19-11-2011, 10:49 PM | #316 | ||
You might be out of warranty now. The hatchbacks have faults leaking water through the rear. I had the rust in there fixed under warranty. Have a look under the faults Focus thread at the top of all these threads and you will see what other owners have done.
They all seem to smoke under certain load _I like pressing the throttle down for smoke effect when I have a tailgater -they back off after teh diesel smoke stench filters through their air con vents. |
20-11-2011, 02:49 PM | #317 | ||
Thailand Specials
Anyone else here find the aircon sort of average? It was a 35 degree day on Friday and with it on for a good hour to 1 hour 20 mins it only gets the car "cool", not "cold"? Its not as crappy as my WS Fiesta, but its not great either.
20-11-2011, 04:26 PM | #318 | |||
20-11-2011, 04:32 PM | #319 | |||
Thailand Specials
20-11-2011, 05:32 PM | #320 | ||
Depends on where you go but you'd be looking at a few hundred, I got mine done when I got the car through the dealer so not too sure.
20-11-2011, 06:28 PM | #321 | ||
Torquer
Around $250 for a decent job. I've never owned a car without tint, it's a must have for me.
Just make sure you check it afterwards, some installers seem to think bubbles are normal.
20-11-2011, 08:36 PM | #322 | ||
Thailand Specials
I'm probably going to go through tint a car in Sunbury, I'm going to ring up for a quote tomorrow.
They've got two tints there, Octane and Midnight Express? Whats the difference? So far I've amassed: - Eibach pro-kit springs - 22mm Whiteline adjustable rear swaybar and assorted camber kit and links - Code:RED CAI Now, I'm thinking about changing the OEM tyres out for some Continental's and looking at the intercooler and high flow cat. I'm going to collect everything, then i think it'd be better to have everything done at once, only one labor cost then. |
20-11-2011, 09:25 PM | #323 | |||
22-11-2011, 07:04 PM | #324 | ||
Thailand Specials
Anyone know if Mazda 3 stuff is interchangable with our Focus?
22-11-2011, 11:14 PM | #325 | |||
23-11-2011, 06:06 PM | #326 | ||
Torquer
Well the downpipe and cat are now done and are free-flowing.
First impressions: The car wasn't loud enough with the stock cat and straight pipe but I can safely say that is no longer a problem. With all the whistling and air blowing it sort of sounds like I'm driving Darth Vader on steroids Can't really test the performance much in this rain but it feels even more responsive and torquey than before.
24-11-2011, 08:44 PM | #327 | |||
Just watch that torque though ! I have just had to shell out $ 503.00 for 3 x Engine mounts for my 2007 TDCI...plus fitting costs..(43,000 kms)Pretty RS I reckon, only 6 months out of warranty. Maybe, the torque of the TDCI is too much for them to handle...Only know ...I ain't happy!!!! All the best Chicka |
24-11-2011, 11:47 PM | #328 | ||
the mazda 3 MPS which is a close-ish relative to the focus also has engine mounts going early. not sure if it's a common problem for the XR5
25-11-2011, 09:39 AM | #329 | ||
They probably use soft mounts to lessen the vibration at the expense of length of serviceable life. Its the sort of thing they will not see as a "problem"
25-11-2011, 06:55 PM | #330 | |||
Thailand Specials
I find the turbo in my car very quiet, sometimes you can hear it with the window down and giving it a bit of curry, slight whoosing noise. Also does anyone think the OEM goodyear NCT 5 tyres are completely rubbish? They don't grip real well and they squeal fairly easily. Not only that but it doesn't take much to spin them, even in torque limited 1st gear, taking off with 1/4 throttle will see the front right spin. Also I'm finding the brakes on my car, they're not too great, you push the pedal down, get the whole leaning forward in your seat thing, but you don't come to a stop quickly, it seems to nose dive but not really stop, I guess it could also be the tyres affecting braking distance too. My WS Fiesta stops much better, but that might be because its a very light car. |
