Old 24-09-2024, 11:13 PM   #811
Boosted_G6
Default Re: FORD technical service bulletin : ICC touch screen display
Ok so running a recore
Mine currently does not want to work :(
I get a strange error coms error when I hit recore
Elm327 cable does quality matter tried in hs and Ms mode but no luck
Also for some reason my radio station with blank screen icc, on my cluster it self it shows up as audio Off but music is playing my cluster is all working before
Does this mean my unit has died completely and not just a simple recore flash is needed
Boosted_G6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2024, 12:52 AM   #812
Amraks
Originally Posted by Boosted_G6 View Post
Ok so running a recore Mine currently does not want to work :(I get a strange error coms error when I hit recore Elm327 cable does quality matter tried in hs and Ms mode but no luckAlso for some reason my radio station with blank screen icc, on my cluster it self it shows up as audio Off but music is playing my cluster is all working beforeDoes this mean my unit has died completely and not just a simple recore flash is needed
I'm yet to get a Elm327 to try a recore in the car.But I have used the UART with pin 6 and seen its got a heap of corruption.yours might be as bad as the one I am trying to fix. If only we knew if replacing the ram chips would work or if its the flash chip. can these chips be blank and still accessed by ODB2? Because if that's the case Ill order the chips and the stencils(if needed) to reball new chip.
Amraks is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2024, 05:13 PM   #813
Amraks
I managed to play with this some more today so far I have used
repair.ino.elf
it has output a repair.log
and dumped the folder and files contents.I think What i need next is a good copy of the files.
Old 27-09-2024, 10:11 AM   #814
Amraks
here is commands in case you just get heaps of scrolling text of stuff trying to start up.
slay media-player && slay mme-generic && slay aviage_monitor && slay devb-umass && slay iosetup && slay ApiPostInitialise && slay bluetooth
Old 27-09-2024, 10:34 AM   #815
Amraks
Originally Posted by Amraks View Post
I managed to play with this some more today so far I have usedrepair.ino.elfit has output a repair.logand dumped the folder and files contents.I think What i need next is a good copy of the files.
Anyone wanna send me a PM with the repair.zip
Old 04-10-2024, 07:31 AM   #816
Whiteford
Ballad of a dead man
Whiteford is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2024, 09:08 PM   #817
Amraks
Today I had a look at what is going on with Boosted_g6's ICC
It was spitting a error about no partition been found where all the package files are stored I take it there is 2 partitions one for the QNX environment and the second one for the packages and scripts. I took the liberty of removing the flash chip to see if the environment would load to make sure that the environment wasn't being run off the arm chip. well I confirmed that there is 2 partitions on this chip. the environment part must not wear out like the scripts part of the chip as someone has said it would be from constant writes onto the flash memory that is wearing them.few weeks from now Ill order a BGA63 jig to read the drive raw onto the computer.then I will also order some new chips and see what I can achieve getting this running again.
