Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
28-09-2024, 02:19 PM | #2132 | ||
Yes; it's where I bought my last headlight for my MKII FG XR6 after someone killed it in a carpark (I suspect vandalism but perhaps it was a towbar) so I naturally thought.....
regards Blue |
29-09-2024, 06:34 PM | #2133 | ||
Hi all, looking for a genuine FGX Ute reverse camera and any instructions on install. I have a secondhand ICC unit which is camera ready and SAT NAV which I currently don't have.
any help would be appreciated. |
30-09-2024, 06:58 PM | #2134 | ||
Hi GTLEGEND ,
Can you get part number BAFF06004A1 Glove Box latch Cheers |
30-09-2024, 09:42 PM | #2135 | |||
30-09-2024, 10:11 PM | #2136 | ||
17-10-2024, 07:44 AM | #2137 | ||
Hi GTLEGEND,
Im looking for the part number for the boot hinge from a BA XR6. The bolt has rusted off and need to find a replacement. Thanks. |
17-10-2024, 09:20 AM | #2138 | ||
17-10-2024, 09:54 AM | #2139 | ||
28-10-2024, 03:23 PM | #2140 | ||
28-10-2024, 05:39 PM | #2141 | ||
Greetings GTLEGEND,
Would you know if the combination headlight, parlklight switch for the Ford AU2 year 2000 6 cylinder still available. For some bizarre reason I turned the switch fully reverse. Now the switch will not switch on or off unless I take the knob off and turn the dial with fingers. |
28-10-2024, 08:10 PM | #2142 | |||
Dark Graphite or Warm Charcoal colour? I doubt it but let me know which one and Ill check it out. GT |
29-10-2024, 06:20 PM | #2143 | ||
GT
Hmm,. not sure but could be Dark Graphite. Thanks |
04-11-2024, 11:04 AM | #2144 | ||
It's not an FG MKI.......
G'day GT.
Chasing P&A for a turbo to dump pipe gasket for an FG turbo. Posted to 0830 please. Thanks.
06/08 Manual FG XR6T. Not an FG1 or MKI, an FG... Want to know how to do an A Service for an FG XR6T? Look in this http://fordforums.com.au/showthread.php?t=11339404 Thinking of oil sampling your engine? Have a look at this trend http://fordforums.com.au/showthread....ght=oil+sample |
04-11-2024, 01:17 PM | #2145 | ||
04-11-2024, 02:22 PM | #2146 | ||
04-11-2024, 03:28 PM | #2147 | |||
04-11-2024, 05:12 PM | #2148 | ||
I’ll get the VIN to you by tomorrow morning, have gone home for the day (rare earlymark).
04-11-2024, 06:24 PM | #2149 | |||
SX SY Heater Hoses.png SX SY Heater Hoses 2.png |
04-11-2024, 07:04 PM | #2150 | ||
It really looks like 18495 in the first image.
That’s the earlier setup? |
04-11-2024, 07:24 PM | #2151 | ||
Apparently the hoses 7890A and 7890B are not great either.
04-11-2024, 07:31 PM | #2152 | ||
04-11-2024, 07:40 PM | #2153 | |||
Regular...with metamusal
none of my business .. [so you can tell me to...] but .. would it not be betterer to chat with the customer re replacing the whole unit & fitting an air cooler?. i'm presuming the assembly is no longer available new?. had to replace the one in her original BF ..... some how the 2nd BF is fine?. the unit on my BF had been replaced before i bought it and hard lines fitted [BA manifold & gearbox]. |
04-11-2024, 08:02 PM | #2154 | ||
05-11-2024, 11:08 AM | #2155 | ||
The VIN is:
6FPAAAJGAT6J79755 If that helps narrow down the possibilities. |
05-11-2024, 11:27 AM | #2156 | ||
05-11-2024, 12:17 PM | #2157 | ||
Thank you for following it up. We’ll have to find a butcher’s solution. :-o
07-11-2024, 04:26 PM | #2158 | ||
Hi GT. Is the FG Ute fuel fill pipe hose (the big one) available anywhere? I assume it is not the same as the Sedan hose. Got a diagram you can share too? There is vent hose on there too I think that has a push connect fitting, wondering if that's available also.
-15 Ford Falcon FGX XR8 Auto -14 FPV Pursuit Ute #47 Auto -12 FPV Pursuit Rspec #44 Manual -11 FPV GS Ute #225 Manual -10 FG XR8 Ute Manual Sold -06 BF XR8 Ute -75 XB Falcon Coupe 351 GT replica -73 Ford Mustang convertible 351 -20 Ford Mustang GT Convertible |
07-11-2024, 07:36 PM | #2159 | |||
Have a look at the image below, is it just 9034 you are after? If so I need to know if it has a factory body or tray/cab chassis type rear as they differ between the two. FG Ute Fuel Tank.png |
08-11-2024, 09:08 AM | #2160 | |||
It looks to me like the hose is part of the filler assembly in that pic and not separate (circled in my pic below). Good work Ford! What are they thinking. So yes 9034. Also is there a part number for the vent hose that goes to the tank (also circled) Thanks! Pic with circled parts: https://ibb.co/bvyRYWH Sent from my iPhone using Tapatalk
