Old 22-04-2022, 03:42 PM   #31
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Recommended tuners in Perth?
Originally Posted by Tratado Injustamente View Post
So two people clearly didn't get the point i was making.
Who is "thinking" again?
Seeing as you're new here (again) behave or begone!
Old 23-04-2022, 07:01 AM   #32
PooDog
PooDog's Avatar
Looks like youve done similar to mine in signature , i used a small duration 264 comp cam to avoid getting it tuned but in the end had to because of this rolling surge it had that was just annoying
As said before theres very little benefit (power wise )better torque spread but for the $ spent its probably not worth it ....definately drives a lot better , if you can get it to run ok IMO i wouldnt bother , just check your A/F ratios on a dyno
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2022, 07:07 AM   #33
PooDog
PooDog's Avatar
524nm torque
Old 23-04-2022, 08:17 AM   #34
five 7
five 7's Avatar
Originally Posted by Chrysler View Post
Ah, a tuner is now the least of my worries. I just punted a tow ball taking the car for its first official cruise down south when I hit someone who suddenly slammed on their brakes when we both took off from a green light.
Fark!@ Anyone have a spare AU XR nose cone or knows a really, really good plastic welder???
Give these guys a call https://www.dennispanelpaint.com/ even if it's only for paint ask for Sam, you won't go wrong, he has a passion for paint plus likes Fords to boot. Tell him Mark with the 57 from West Auckland sent ya.
five 7 is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2022, 10:49 AM   #35
GTENVY
GTENVY's Avatar
Bugger, sorry to hear mate. Hopefully you can either get another bar or get this one repaired soon.
Rich
FM Mustang GT, manual - Daily driven
Live, Love, RACE
SOLD: AU III XR8
Originally Posted by nstg8a
cars are to be driven, ornaments are to be looked at. the two should never be confused.
GTENVY is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2022, 12:14 PM   #36
TICKFORD220
2009 xr turbo,2004 fiesta
Chad at streetbuilt did a good job tuning my 220 au,i know they are closed up now but if you can contact chad(scaffy) on here he might be able to shed some light on your issue,or not?
im glad my windsor is gone now,gene pool is way too small for windsor tuning here in perth(non existant),ford tuning full stop.....
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2022, 06:00 PM   #37
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Well, I may have dodged a bullet. Car is almost back on the road, but while it was on the hoist refilling the fluids I lost oil pressure. Sure enough, oil pump regulator failure. I put a new oil pump in it last night and will have it going later today.
I dodged a bullet because at the time of the prang, the missus and I were off on a 500km round trip down south. Had I not had the accident, the oil pump would likely have failed in the middle of nowhere.
The cause of the regulator failure (stuck in the partially open position) was a bit of carbon that had either been knocked off during the rebuild or was washed loose with the oil flush prior to removing the engine. There was some galling inside the impeller, too, which indicates there was a bit of **** in it. The engine has since been flushed.
Oh, and installing an oil pump when the engine is in the car is a mongrel of a job. Had to drop the K-frame, which was a chore in itself. Lucky I had access to a hoist.
408 Charger 5spd - 11.666@121mph /\:T:/\ AUII XR8 Rebel - 220kW auto
Chrysler is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2022, 06:01 PM   #38
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Thanks to all the suggestions on where to get the car fixed and tuned. Sorry for the late reply, but obviously I've been busy trying to find parts to help the panel beaters out.
Old 12-07-2022, 04:03 PM   #39
ivorya
Mad Scientist!
ivorya's Avatar
https://www.youtube.com/watch?v=GyaC4vutJs4&t=439s
Watch this. A tuner maybe able to get in touch and remote tune for you.
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2022, 03:42 AM   #40
Chrysler
Mopar or FoMoCar
Chrysler's Avatar
Mate, that's very interesting. I've got the car back now and it's been running pretty well with the factory ECU but is still a little on the lean side. I'm not sure I can afford the $3500 for an FT550 at this stage, but compared to $1000+ for a base tune, I don't doubt it's worth it.
Old 17-07-2024, 11:02 PM   #41
El Sucio
El Sucio's Avatar
Slight resurrection.
I’ve gotten back into the AU game recently, picked up a 220kw series 3 XR8. I’ll get a build thread going soon.
I’ve used BPT for several cars over the years, 2x AU’s, couple BA, a BF, an FG, wagons, utes, sedans, 6 and 8.
I’ve been very happy with their work on my Windsors, they built their business doing stroker and blower packages for these cars.
I’ve never had a bad experience with them and any dissatisfaction with my tunes have seen the car back there to fix no questions asked.
Like anything in this scene, be honest with the condition and mods have been done, what you’re looking for and what you want to spend.
I need to get my backside down there to sort out a cough and some spluttering under load in the 220kw Windsor I’ve got…I’m sure a few ponies have escaped in the last 22 years.
2002 AU III XR8 220kw
Previous Rides:
KH Laser TX3
EF Futura (RIP)
EL XR6
AU2 XR6
BA XR8
BF XR8
BF Wagon (XR6 Lookalike supercharged)
2014 Ford Ranger XLT
2000 AU XR8 with all the options boxes ticked (RIP)
2005 BA Mk 2 Fairmont Ghia V8
2012 FG Mk 2 XR6T
G.M.H. - Get a Mechanic...Hurry!!
El Sucio is offline   Reply With Quote Multi-Quote with this Post
