Old 23-04-2006, 07:36 PM   #1
S3SR
S3SR's Avatar
Default AU motor into EA
a friend has an EA spac or something and is it possible to get an AU motor and unbolt the manifolds and other crap off the EA motor then drop the AU motor in and bold everything back on..??? ..im thinking at least may have to keep the AU intake manifold and maybe use the AU airbox.... comparing the 2 side by side it looks almost the same that is everything around the motor..
any help or anyone who knows thanks
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2006, 09:14 PM   #2
S3SR
S3SR's Avatar
wow 36 views and not one comment ah well anyways u guys are helpful in every other way but ive got my info the answer is YES it should easier to keep the intake, replace exhaust but might fit straight on, change ECU, might have to change gearbox might not....but EA has more power than my AU or i cant drive.. eh
Old 24-04-2006, 09:17 PM   #3
LUXO_8
windsor user
ea manifold will go on. need to grind sump to clear k frame. need to either keep the serpentine belt (meaning run the AU accessories - alternator, power steering pump, air con compressor) or convert it to ribbed belts (more grinding aparently...SPHELL has done this in the past on his old EA)
the reason you probably got no replies is because you posted it in the AU section......
Old 24-04-2006, 11:43 PM   #4
Smoked
Burnin Rubber
Smoked's Avatar
Yeah, post this in the E-series area if you havent already, they will definatly have an answer.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 01:26 AM   #5
EvilChief
Boost Addict
search
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 08:42 AM   #6
SWOOP
XRSVO
SWOOP's Avatar
easier to do an el motor ,there are alot of small things that make the au convert a pain and fiddly
for not much more gain than earlier motors
SWOOP is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 05:44 PM   #7
S3SR
S3SR's Avatar
well it wasnt really for any real power gain just the AU motor seems to be very common on the ebay and wreckers market thats all but weve decided that we'll just get an EB motor or E-series at most not the AU motor
Old 25-04-2006, 07:23 PM   #8
Damo
try and find a late ED motor they had EF internals and will bolt strait in with out swapping belt setups manifold etc.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2006, 07:43 PM   #9
S3SR
S3SR's Avatar
was the ED a 4.0L that would be a bonus
Old 25-04-2006, 07:45 PM   #10
LUXO_8
windsor user
EB2 on were 4.0L
