03-11-2018, 04:36 PM | #1 | ||
Hi
I had to change the brake pads on my mk7 FiST the other day so I jacked the car up using the normal jack first and then used a trolley jack on the blue spots in the pic , was that a safe place ? car looks and drives fine just want to make sure if I need to again in the future its ok https://i.imgur.com/b3KWbS4.jpg |
04-11-2018, 02:30 AM | #2 | ||
From the workshop manual, it should only be jacked from the side points as per the attached.
WZ Jacking Points.doc Last edited by GTLEGEND; 04-11-2018 at 02:40 AM. |
04-11-2018, 12:09 PM | #3 | |||
a shame there's no central spot it would make it so much easier |
24-03-2021, 04:53 AM | #5 | ||
Where did you put the jack stands? You mention the jack points
