01-02-2021, 05:05 PM | #1 | ||
Hi all
I recently had the leak off pipes replaced due to one leaking (which ultimately caused a small fire under the bonnet ). A certified reputable mechanic did this replacement . Unfortunately the leak off pipes keep popping out , it’s not always the same one . The clips are new also, also no pressure issues . Has anyone had this problem and been able to solve it . I can’t really drive it as you never know when one is going to pop out . 2010 mondeo titanium tdci . |
02-02-2021, 10:19 AM | #2 | ||
Metal cips or green plastic tabs?
They changed sometime in 2010 I gather. http://www.catcar.info/ford/?lang=en...ODg4OCsxMzM%3D shows (9A317) a metal clip. These potentially get weaker by over extension when installing. Solution might be to bend them back a bit. They should be installed before the leak off pipe is pressed in. Another idea is to cable tie them in as emergency backup. I googled it out of interest, no problems with mine, plastic tabs. |
02-02-2021, 10:30 AM | #3 | ||
They are the metal clips
