22-09-2019, 05:01 PM | #1 | ||
Guys,
Can someone tell me which fuse is the Brake Lights, currently both brake lights and the centre rear screen brake light not working. I will try the easy option first. Or globes are OK. AU Series 3 XR8. Cheers |
22-09-2019, 05:50 PM | #2 | ||
The Terrain Tamer
Have a look here.
https://www.fordforums.com.au/vbport...articleid=1582 Looks like No. 5 is the place to start.
Current Ride : A Ford owned D3... |
22-09-2019, 08:01 PM | #3 | |||
Regards |
22-09-2019, 08:45 PM | #5 | ||
Hi. Use a test light to check each side of the switch on the brake pedal, its a common failure point. Cheers MD
22-09-2019, 09:05 PM | #6 | |||
Cheers |
22-09-2019, 09:07 PM | #7 | ||
23-09-2019, 03:18 PM | #8 | ||
TSCoA member Qld
If your car is fitted with a boot mounted spoiler check the wiring harness that runs along the boot hinge as this is a common pinch point where the wires break. This happened to me
Cheers, Martin Mac. 2002 AUIII TS50 Liquid Silver #206 (ex NZ) T-Series Club of Australia member; QLD |
23-09-2019, 04:44 PM | #9 | ||
23-09-2019, 05:51 PM | #10 | ||
24-09-2019, 05:54 PM | #11 | ||
24-09-2019, 08:28 PM | #12 | |||
Thanks fellas |
