Old 04-09-2014, 10:18 PM   #1
OffRoadFalcon
"Flooded it mate?"
OffRoadFalcon's Avatar
Default Key fob not working AUII Wagon
G'day everyone,
I've been having an issue with my key fob and central locking lately.
So over the last few months it was taking longer and longer for the car to respond to the key fob, and eventually stopped working entirely. The light on the key fob didn't light up either. So I replaced the battery thinking this would fix it, but no!
The key fob works as normal, with the little red light flashing as soon as I press the buttons, but the car's central locking doesn't respond at all.
Any ideas?
Thanks,
Chris
OffRoadFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2014, 10:25 PM   #2
99AUXR
Brad
99AUXR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Installing starter motor advice on ba / bf 6cyc Falcon.
Default Re: Key fob not working AUII Wagon
Recode the FOB to the car
Turn the ignition key to the accessories position.Within 5 seconds of turning the key, hit the rear demister button (center console) three times in succession.The door locks will cycle once to indicate the special mode has been entered.Press any button on the remote you wish to program.The doors will cycle to indicate a new remote has been programmed.Continue steps 6 and 7 for all remotes (including existing ones) you intend to use on the vehicle.When you've programmed all the remotes, turn the ignition key off. The doors should cycle again to indicate the programming session has been completed.
This is for a sedan a wagon might be different, if the above method doesn't work try the tail gate button 3 times instead of the demister.
Silhouette BF MKII F6
Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10
99AUXR is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2014, 10:46 PM   #3
OffRoadFalcon
"Flooded it mate?"
Cheers mate, will give this a go!
Appreciate the help!
Old 04-09-2014, 11:24 PM   #4
OffRoadFalcon
"Flooded it mate?"
Just gave this a quick go, didn't seem to get anywhere, neither the rear demist or tailgate button 3x presses led to the door lock cycle.
Any more ideas? Otherwise I'll try again tomorrow.
Old 04-09-2014, 11:26 PM   #5
towtaltowing
keep trying it mate took me about 10 gos before my locks cycled
towtaltowing is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2014, 01:46 AM   #6
superroo
You can't stop the signal
superroo's Avatar
Three times means on-off-on.
Try it in quick succession
Old 05-09-2014, 10:51 AM   #7
99AUXR
Brad
99AUXR's Avatar
Unsure if its the same for the AU but my radio was off in the BF and it wont cycle unless the radio is powered on.
Old 05-09-2014, 12:04 PM   #8
OffRoadFalcon
"Flooded it mate?"
Cheers guys, I'll keep trying today and see how I go!
Interesting point, because my radio is also turned off! Will turn it on and see.
Old 05-09-2014, 12:19 PM   #9
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Mate, I just had the same problem yesterday where the key was not opening the door. I took the trim off the door to find that one of the links that joins the latch to the key barrel was just hanging on to its plastic retainer.
Lucky it was still on, otherwise I probably would have needed to smash the window to get in. Anyway, fixed for now, but will probably go and get a replacement from the wreckers or find some other way to secure it.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2014, 12:31 PM   #10
TRAU BLAU
Question Re: Key fob not working AUII Wagon
I've got the same problem on my AU 3 Wagon.I've tried reprogramming,new batteries but now use key only.
Live and Let Live
TRAU BLAU is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2014, 12:44 PM   #11
99AUXR
Brad
99AUXR's Avatar
1. Turn the key to the OFF position.
2. Turn the key to ACC (not ON) and press the demister button 3 times within 5 seconds of turning the key.
3. The door locks will cycle indicating learning mode.
4. Press a button on the keypad, the locks will cycle indicating that the pad has been learnt.
5. Turn the key to the OFF position.
^ from the service manual.
Old 05-09-2014, 01:14 PM   #12
OffRoadFalcon
"Flooded it mate?"
Cheers mate!
Old 05-09-2014, 01:19 PM   #13
99AUXR
Brad
99AUXR's Avatar
Working now?
Old 05-09-2014, 01:20 PM   #14
OffRoadFalcon
"Flooded it mate?"
Heading out to the car to try it soon!
Old 05-09-2014, 02:12 PM   #15
OffRoadFalcon
"Flooded it mate?"
Followed your instructions mate, worked a treat! All good, works perfectly now!
Big thanks for the advice!
Old 05-09-2014, 02:19 PM   #16
99AUXR
Brad
99AUXR's Avatar
No worries Enjoy!
Old 24-07-2019, 03:01 PM   #17
jk54
new au owner
Unhappy Re: Key fob not working AUII Wagon
I followed all the suggestions on the forum and still no luck to get the after market remotes to work an my au2 sedan. Replaced all the interior globes and they are now working. The rear demister does not light up after 3 presses of the rear demister button. Any other suggestions as this is starting to frustrate me.
jk54 is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2019, 10:43 AM   #18
TRAU BLAU
Cool Re: Key fob not working AUII Wagon
G'day,jk54.The same happened to me on au wag,3.How old is the key-fob?If old or original my advice would be to buy a new one!(+new alkaline bats.)Which is what I did.Follow the basic method of programming found in the manual or car booklet & it should be "as right as rain."
Live and Let Live
Old 26-07-2019, 10:51 AM   #19
jk54
new au owner
Thanks for this info. The remotes are after market and brand new, bought them on ebay. Will try again when I get the car mobile. Not in a hurry at this time as the front end is being repaired. jk54
Old 26-07-2019, 02:51 PM   #20
11ford11
Would suggest you start your own thread instead of using a 5 year old one
Rear demist won’t come on in accessory position
Close doors turn ignition to accessory position push rear demist 3 times locks in door should cycle then push button on remotes
Are remotes aftermarket or second hand as not all aftermarket remotes will program
Old 26-07-2019, 08:30 PM   #21
Bill M
Bill M's Avatar
Default AU 2 3 Falcon Genuine Ford remote Ebay
I bought my last remote from this seller on Ebay. Genuine Ford and better than stuffing around with aftermarket. However if one is saving a dollar...
https://www.ebay.com.au/itm/Genuine-...0AAOxy4dNSxTbg
https://www.ebay.com.au/itm/Genuine-...frcectupt=true
AUII XR6 VCT ute
20 years and still going strong!
Old 26-07-2019, 09:10 PM   #22
jk54
new au owner
Default Re: AU 2 3 Falcon Genuine Ford remote Ebay
Thanks Bill will have a look jk54
Old 02-04-2023, 04:31 PM   #23
asimplelife
mechanical novice hopeful
I had exactly the same symptoms as the OP...so was sure this re-programming the remote would solve my problem...but it didn't.
So I took the opportunity to go through the bag of spare remote keypads/keyfobs I have collected over the years, tested all of them and these are the problems I found, after opening them up;
- the battery cradle had broken away from the printed circuit board...the gradualness of this process must have been why mine did work some of the time...until it stopped altogether
- on the other side of the printed circuit board, one of the button contacts had broken off one remote
- sometimes I found that a button when pressed through the rubber would not work and also the red led did not come on. However when opened up, I could press the contact on the printed circuit board directly and the red led would light up. In all cases after a thorough spray and clean with alcohol, I was able to make the buttons work when re-assembled. From the colour that came off and sometimes the stickiness, I presume this problem is caused by spillage.
Note - even when fully cleaned, some remotes just press and respond better than others.
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2023, 05:15 PM   #24
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I think this will be an issue as they age. If anyone is planning to keep a
AU long term it would be wise to by some new fobs, program them and put them in a dry place.
Old 10-04-2023, 10:32 PM   #25
Whoosha
AU DIE HARD
Whoosha's Avatar
My originals both fell apart internally after 6 years , strangely enough the Flea bay repro 1s are still going strong with no sign of the battery points breaking away from the circuit
Originally Posted by Riksta
