Old 08-03-2016, 04:34 PM   #1
naughts
Hmmmmm Mulberry....
naughts's Avatar
Default AU fuel pump problems
Howdy
Got a AU ute and the fuel pump is not running. Relay is switching on but pump not running. Can hot wire the pump, so i know its ok.
Has anyone got a wiring diagram of the fuel pump circuit they than post or send me. Have looked online here, but it is barely readable, and i cannot print it off.
Thank
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2016, 12:20 AM   #2
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Have you tested that the relay is working, or are you hearing it click and assuming that means it's ok?
Try swapping the relay with another as a test if you haven't already.
Good luck with it!
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2018, 06:18 AM   #3
manaaki04
Default Re: AU fuel pump problems
I've got the same problem I know the pump is fine but have no power from the body back to the pump
Sent from my SM-G965F using Tapatalk
manaaki04 is offline   Reply With Quote Multi-Quote with this Post
