Old 24-05-2016, 03:59 PM   #1
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Default AU Wagon baby seat mounts
I just purchased a run around s111 forte wagon and I can't find any mounts for a baby seat.
There appear to be 4 cargo mounts but offset to a position that isn't suitable, I pulled the carpet up and couldn't see any, and there is nothing visible on the rear of the seat.
Surely these were standard from factory? Any hints.
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2016, 08:00 PM   #2
foxtrot3
foxtrot3's Avatar
Default Re: AU Wagon baby seat mounts
Hi. According to the workshop manual the child restraint points are on the back of the seat backrest. The centre one should be factory fitted and there should be a plug for each of the others fitted to the car. If the plug is there it is about the size of a 20 cent coin with a screwdriver slot in it. http://fordforums.com.au/wsmpub/augx/Part%2018-5.html . Cheers MD
HI
I'M MICHAEL
Old 24-05-2016, 08:09 PM   #3
falcon_bandit
theres a single threaded hole on the floor behind the both outer seats, and the middle seat has a mount built into it i think, but is not recommened according to the manual
falcon_bandit is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2016, 10:19 PM   #4
Davehoos
the 2 threaded holes in the rear floor have the large plastic round plug to hold the carpet in place. the center seat position should have the mount attached from factory on the back near the top half.
The center seat should not be used unless you like most wagon buyer and need 2 booster seats.
the recommendation for child seat anchor by the seat makers is that the attachment strap should be near horizontal and not drop at a steep angle. old conversions you had to fit mounts to the roof or a pipe added across the rear door. My wagon all had cargo barrier and the outer strap run through the guide hole.
In the past I had used the extra addon harness used in the past for smaller children before the new laws for booster seats. these are considered dangerous now as in a crash the belt pulls down across the shoulder.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA-
Land Rover 88
.MIDCOAST NSW.
Davehoos is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2016, 02:47 PM   #5
ten[A]cio[U]s
Thanks all - Very much appreciated . I saw the two holes but given its the safety of my son wanted to confirm.
The seat mount provided with the car seat thread perfectly. It actually gives mew more confidence than the factory fitted FG mount.
