Old 14-03-2011, 03:46 PM   #1
Bolly
Bolly's Avatar
Default Sunroof
Ive got the tickford sunroof on my AU2 XR8 and ive noticed that the sunroof glass seems to rattle over bad bumps when closed..Not a problem when open.. In the closed postion ive got slight up and down movement when pushing the glass from the inside with my hand..Thought id ask in here before attempting to adjust the glass slides myself.
Is the job too involved? or should i just take it in to a sunroof Shop?
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2011, 05:20 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
is yours one of the ones affected in the recall?
Old 14-03-2011, 06:10 PM   #3
Bolly
Bolly's Avatar
No..I had a tickford Sunroof installed 3 years ago.. Im surposed to have it serviced once a year but they are in town and wont service on Saturday`s.
They want the car for half a day but the service takes 45mins..The problem is i have to take the day off work..
If the sevice isnt that hard id do it myself.. just waiting on here for a answer .. do it myself job or is it a `too hard` job! If it is., ill just take the day off and have it serviced.
Old 14-03-2011, 07:28 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
Is the service a freebe or are you paying for it ? if your paying for it there are plenty of reputable sunroof dealers around that will service it , I presume its a Hollandia (splelln)
Originally Posted by Riksta
Old 14-03-2011, 09:39 PM   #5
FGII-XR6
FGII-XR6's Avatar
check here to make sure it's not covered "Hollandia 700 sunroofs manufactured from 2002-2009" are covered by the recall so you might be lucky
[SIGPIC][/SIGPIC]
Rides:
Old 15-03-2011, 06:00 PM   #6
Bolly
Bolly's Avatar
Hey thanks ..au3xr6..
Checked the serial number and the glass has to be replaced..So ive booked the car in for the sevice as well..
Old 10-10-2015, 03:14 AM   #7
markscottefxr8
drive hot Cars just cause
Default Re: Sunroof
ford just had to reprogram my keys and ****** the lot up, changes my bcm, ecu etc, So eversince my sunroof aint worked,, ive argued with then but they know best,, ,my ***,,, ****en tried to charge me 1800 bucks when i just towed it there and said my keys have been flogged out of my house.,,, ****en I take it the BCM they used isnt programed for a sunroof,, ill try n by pass it,, if so
markscottefxr8 is offline   Reply With Quote Multi-Quote with this Post
