08-12-2006, 10:57 PM | #1 | ||
Walking with God
Hi guys,
Was told that the EF/L and AU auto boxes are essentially the same. They are a straight swap over for size etc right? The shifts are different though from what I understand. The AU's got different points and 3rd locks out, then shifts into 4th and locks out again. All for economy. If that's actually the case, would a box from an EL that's in good nick be better? I do know that they have the transmission oil filler also. I'm thinking about a swap over for about $350. Your thoughts please. GK
08-12-2006, 11:00 PM | #2 | ||
The dipstick tube can be retrofitted to the AU gear box. I've had mine done.
Is there a problem with your AU gearbox? |
08-12-2006, 11:08 PM | #3 | ||
not here much anymore
GK - for reference, the gearbox filler tube stopped after EF Series I. No EL's had them.
RAM 1500
09-12-2006, 09:49 AM | #4 | |||
Walking with God
GK
09-12-2006, 09:50 AM | #5 | |||
Walking with God
GK
09-12-2006, 09:26 PM | #6 | ||
If it is clunky, it sounds like solenoid issue. When was the gear box last serviced??
10-12-2006, 12:39 AM | #7 | ||
AU2 XR8
clunky into second is an s5 solenoid fault the only if you swap to an el trans it wont work any different than your trans unless you change the trans computer to an el one
10-12-2006, 10:03 PM | #8 | |||
Walking with God
GK
10-12-2006, 10:14 PM | #9 | ||
www.TUFFCARPARTS.com
GK, when you say it's clunky is it sloppy on down shifts but fine on upshifts? Mine has become a bit sloppy and clunky over the last few months and I had assumed that it was becuase the poor thing had never had an auto service.
Just recently had it done though and it was found to be in good health. Mechanic did mention something about a solenoid though so next service will be looking into this. Would definitely be worth your time looking at the solenoid compared to a changeover though - fairly considerable price difference! |
10-12-2006, 10:56 PM | #10 | |||
Walking with God
GK
10-12-2006, 11:00 PM | #11 | |||
11-12-2006, 05:00 PM | #12 | ||
Smile
My au has an ef box in it .
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
11-12-2006, 09:37 PM | #13 | |||
Walking with God
GK
11-12-2006, 09:38 PM | #14 | |||
Walking with God
How do you find it? GK
11-12-2006, 10:13 PM | #15 | ||
I just had the gearbox serviced on my 1999 AU and was told by the mechanic that it had a 1995 gearbox fitted to it complete with dipstick, as most of you know my car has a shudder when slowing down which looks to be a Torque converter on its way out but apart from that the gearbox suits the car with plenty of power.
Cheers Tony |
11-12-2006, 10:26 PM | #16 | |||
Walking with God
GK
18-06-2015, 12:44 AM | #17 | ||
Hi all
So will an EL auto gearbox/transmission fit into an AU without any trouble? My Dads AU2 box needs replacing and I have access to a very good EL box will anything else be reqired? Thanks |
18-06-2015, 01:53 PM | #18 | ||
In a word, Yes. Straight swap out, no difference whatsoever.
18-06-2015, 04:41 PM | #19 | ||
Next upgraded Mk1 Leopard
Well said Casper.
Uk (And good to hear from you
18-06-2015, 06:13 PM | #20 | ||
I still drop in now and then to see whats happening. I dont often post anymore but I still like to keep up to date. I still love the AU's.
Good to see some of the old school team still here.
19-06-2015, 01:32 PM | #21 | ||
Thanks for the conformation Casper and Ken vary much appreciated.
28-06-2015, 06:38 PM | #22 | ||
Spanner Thrower
Thought i might throw in a thought, (not sure if 100% Relevant or not though.) but you might have to change the extension case on the rear of the gearbox, the transmission mount bracket, and maybe the bellhousing.
I Swapped out my AU1 Wagon box for a EF Sedan one. had to change the bellhousing (different bolt pattern), extension case (Length was shorter on the sedan) and extension case bracket (black metal part) for it to fit correctly.
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
