Old 27-03-2014, 12:09 AM   #1
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Ford capri gt 1972 front valance panel
[HI ALL
JUST LIKE TO KNOW . I AM STARING TO FIX A FEW MORE THINGS UP ON MY CAPRI MK1.
CAN YOU UNBOLT ALL THE FRONT VALANCE OF THE CAR WITH OUT CUTTING AND BODY. I HAVENT GONE FOR A LOOK .
SO FROM THE BOTTOM AND TAKE OF AROUND WERE THE GRIL IS ON THE TOP..
IF ANYONE HAS SOME NO HOW PLEASE TELL..
CHEERS
JETSTAR
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2014, 06:34 AM   #2
xxx000
Default Re: Ford capri gt 1972 front valance panel
I'd really doubt it, can't recall a car where it isn't welded in
xxx000 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2014, 09:53 PM   #3
allanv6gt
Tippy-tronic Free Zone
The front valance bolts to the front skirt of the mudguards only.
It is spot welded along the seam at the base of the grille and headlights.....and the braceing piece behind the centre of the grille (2 spots at the grille base seam and two spots on the valance itself lower down).
You may also find the top outer corners (under indicator) are braised to the guards.
Use 1/8 pilot drill followed by 1/4 or 5/16 to drill the spot.
Have fun....
allanv6gt is offline   Reply With Quote Multi-Quote with this Post
