06-01-2014, 08:48 PM | #1 | |||
Back to Le Frenchy
Hey All,
Helping my my late old mans partner sell his old 61 Ford Truck. As can be seen in the pics she's in need of a resto to bring her up and back on the road. I don't know to much about it and wouldn't have a clue when last it ran. The body however is good with minimal rust add it's been kept under cover and out of the weather. Any help with what it is and what it's worth would be appreciated, it'd be sweet as a tow for a race car. Sent from my Nexus 7 using Tapatalk 4
06-01-2014, 08:55 PM | #2 | ||
I am Groot
Looks like a F600, can't help with what it's worth though.....
.. McLaren F1 Dick Johnson Racing "Those were the days when the cars were cars, they weren't built out of an Ikea pack like they are now and clothed in plastic; they were real cars." John Bowe |
06-01-2014, 09:18 PM | #3 | ||
Yes that would have been my guess also....... f600............. looks like last reg was november 2000?
Dunno what its worth as is, but I have seen an f600 with 20 foot tray for a few thousand a couple of years ago, if ihad room for that, I would take it off your mates hands in a second. |
06-01-2014, 09:57 PM | #4 | ||
It's definitely an F600. Or 500.
It's worth somewhere between $2 to $5k. It would be worth significantly more if it was an F100 but this has ha different and heavier chassis, and more obviously the larger front guards.
Oooh baby living in Miami....
06-01-2014, 10:07 PM | #5 | ||
I'd go along with all that
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
06-01-2014, 10:20 PM | #6 | ||
P6 LTD
To find out what it is, you will need to look at the ID plates. Once you have this information, you can then correlate it back to the below
1961 FORD TRUCK IDENTIFICATION PLATE MODEL TRANS. WHEEL BASE TONNAGE NEW F100 Chassis and Cab 4 Speed 114" 15 cwt. 4110 F100 S/S Box 4 Speed 114" 15 cwt. 4120 F100 Cowl and Windscreen 4 Speed 114" 15 cwt. 4130 F250 "Y" Cab 4 Speed 122" 1 Ton 7310 F250 Cowl and Windscreen 4 Speed 122" 1 Ton 7330 F500 4 Speed 130" or 132" 2 Ton 7110 F500 4 Speed 130" or 132" 3 1/2 Ton 7130 F600 4 Speed 130" or 132" 6 1/2 Ton 7211 F600 5 Speed 130" or 132" 6 1/2 Ton 7212 F500 4 Speed 154" or 156" 2 Ton 7120 F500 4 Speed 154" or 156" 3 1/2 Ton 7140 F600 4 Speed 154" or 156" 6 1/2 Ton 7221 F600 5 Speed 154" or 156" 6 1/2 Ton 7222 F500 4 Speed 172" or 174" 3 1/2 Ton 7150 F600 4 Speed 172" or 174" 6 1/2 Ton 7231 F600 5 Speed 172" or 174" 6 1/2 Ton 7232 F500 4 Speed 192 " or 194" 3 1/2 Ton 7160 F600 4 Speed 192" or 194" 6 1/2 Ton 7241 F600 5 Speed 192" or 194" 6 1/2 Ton 7242 MODEL IDENTIFICATION 1961 F100 Truck. ENGINE V8 Type Prefix No: N.R. DISPLACEMENT 292 cu. ins. M. D. NO. OF: CYLINDERS 8 BORE 3.75 STROKE 3.3 HORSE POWER (RAC) 45. 0 COMPRESSION RATIO 8.0:1 TRANSMISSION Four Speed Floor Shift SUSPENSION Front - Semi Elliptic (6 leaf) Rear - Semi Elliptic (9 leaf) REAR AXLE RATIO 3.89:1 BRAKES Hydraulic - DRUM DIA. Front - 11" x 2" Rear - 11" x 1 3/4" TYRES 6.50 x 16 WHEEL BASE 114 IN. CRANKCASE 5 Imp Quarts (Including Filter Change) FUEL TANK 15 Gallons ELECTRICAL 12 Volt SYSTEM MODEL IDENTIFICATION 1961 F250 Truck. ENGINE V8 Type Prefix No: N.R. DISPLACEMENT 292 cu. ins. M. D. NO. OF: CYLINDERS 8 BORE 3.75 STROKE 3.3 HORSE POWER (RAC) 45. 0 COMPRESSION RATIO 8.0:1 TRANSMISSION Four Speed Floor Shift SUSPENSION Front - Semi Elliptic (6 leaf) Rear - Semi Elliptic (6 leaf) REAR AXLE RATIO 4.88:1 BRAKES Hydraulic - DRUM DIA. Front - 12 1/8" x 2" Rear - 12 1/8" x 2" TYRES 7.50 x 17 WHEEL BASE 122 IN. CRANKCASE 5 Imp Quarts (Including Filter Change) FUEL TANK 15 Gallons ELECTRICAL 12 Volt SYSTEM MODEL IDENTIFICATION 1961 F500 Truck. ENGINE V8 Type Prefix No: N.R. DISPLACEMENT 292 cu. ins. M. D. NO. OF: CYLINDERS 8 BORE 3.75 STROKE 3.3 HORSE POWER (RAC) 45. 0 COMPRESSION RATIO 8.0:1 TRANSMISSION Four Speed Floor Shift SUSPENSION Front - Semi Elliptic (6 leaf) 40 cwt. Rear - Semi Elliptic (9 leaf) 40 cwt. Front - Semi Elliptic (7 leaf) 70 cwt. Rear - Semi Elliptic (8 leaf) 70 cwt. REAR AXLE RATIO 5.83:1 Single Speed (40/70 cwt). - Optional 5.83/8.11 Two Speed. (70 cwt.) BRAKES Hydraulic - DRUM DIA. Front - 13" x 2 1/4" Rear - 15" x 4" TYRES 6.50 x 20 - 7.00 x 20 (40 cwt.) 7.50 x 20 - 8.25 x 20 (70 cwt.) WHEEL BASE 132" - 156" (40 cwt.) 132" - 156" 174" (70 cwt.) CRANKCASE 5 Imp Quarts (Including Filter Change) FUEL TANK 15 Gallons ELECTRICAL 12 Volt SYSTEM MODEL IDENTIFICATION 1961 F600 Truck. ENGINE V8 Type Prefix No: N.R. DISPLACEMENT 292 cu. ins. M. D. NO. OF: CYLINDERS 8 BORE 3.75 STROKE 3.3 HORSE POWER (RAC) 45. 0 COMPRESSION RATIO 8.0:1 TRANSMISSION Four Speed Floor Shift 5 Speed (Optional) SUSPENSION Front - Semi Elliptic (10 leaf) Rear - Semi Elliptic (11 leaf) REAR AXLE RATIO 6.50/9.04:1 Two Speed BRAKES Hydraulic - DRUM DIA. Front - 14" x 2 1/2" Rear - 15" x 5" TYRES 8.25 x 20 or 9.00 x 20 WHEEL BASE 132" - 156" - 174" - 194" CRANKCASE 5 Imp Quarts (Including Filter Change) FUEL TANK 15 Gallons ELECTRICAL 12 Volt SYSTEM Doufám, že to pomůže |
06-01-2014, 10:34 PM | #7 | ||
Formerly ST170ish
Make a nice ratty burnout rig... V8 S/C diesel and duallys!
My bad attitude escalates in direct proportion to the amount of stupidity I am presented with!!! |
07-01-2014, 12:38 AM | #8 | ||
Two words:
Rat rod. Do it...you must... |
07-01-2014, 09:33 AM | #9 | ||
That looks to be in way too good a condition for a rat rod (rat truck?)
Something like this (hot rod/race car carrier) would be a better use. Can't help you with what it's worth though, sorry.
5 users like this post: |
07-01-2014, 10:15 AM | #10 | ||
seem to go between $2000 and $5000 but tow truck back actually kills value so dont know ,at a guess between $1500 and $3000 unfortunatly the tow rig means its shortened chassis but with big chassis springs and wheels so needs a fair bit spent to get it back as a tray of usefull size, still if i had cash id be keen on it so there is hope for reasonable sale price as its all about location , due to cost of transport to bring big items to your door.always the killer now.especially if you cant fit them on a tandem trailer.
Just had another look at pics, cab seems to be in such nice order id clean it up and take better pics it could go for higher price just due to fact that panel work will be very minimal,id love it but moneys short,
Hervey Bay QLD Great trades recently- GILMORE BOSSYONBIKE Last edited by OLDFORDNUT; 07-01-2014 at 10:20 AM. Reason: better look at pics |
07-01-2014, 10:34 AM | #11 | ||
Isn't it obvious?
could you not cut the crane off, and then use some of the long pieces cut up to make the frame of a bed and get some timber or steel for tray bit and have a tray truck?
might be a bit high with those guards but they might be able to be cut and lowered a tad?? would look absolutely awesome as a big tray truck in matt black edit just noticed it was a tipper (on rego disc) put high sides on it as a flat bed and have an awesome tipper truck??
08 Strike G6E T. 10 Ergo G6E Sept 75 XB Falcon in mushroom beige, 3 on the tree 200cid for sale, offers in the teens |
07-01-2014, 11:08 AM | #12 | ||
Old trucks like this not just F100's are also becoming collectable......Internationals/Fords/Dodges/Bedfords.........These were the original types of trucks that started the Australian trucking industry...........This one in such reasonable condition and if it runs and drives would surely pull 5k....
Some fresh paint and a good clean maybe even 10k. Ther are vintage truck shows here and ther around the country now nowadays. Mind you it would be bloody expensive to run if its a petrol motor. I would rip the crane and rear guards off and make up a short steel tray with timber boards. Last edited by GASWAGON; 07-01-2014 at 11:16 AM. |
07-01-2014, 12:59 PM | #13 | ||
The more i look at it, the more i think "barn find", crikey it is in nice order for its age, sell he crane and hydraulics at the machinery auctions, have the truck detailed, it is a restorers dream, if i had a small business i would even think about fixing it up for work again.
07-01-2014, 01:30 PM | #14 | |||
07-01-2014, 01:43 PM | #15 | ||
Obsessed with wheels
Yep agreed they are starting to be come popular. A bit of truck wash and a gerni, and she'll probably give us a wow factor.
07-01-2014, 04:18 PM | #16 | |||
Back to Le Frenchy
Thanks for the info guys. The crane has been pretty much grafted on there for idle use (was used for a variety of jobs) as it wasn't ever really a crane.
It was a tipper, hydraulics and all, so turning into a flatbed wouldn't be all that hard. I'll try to get a few better shots when I'm next out there and have a bit of a tinker and see what's what.
07-01-2014, 05:04 PM | #17 | |||
07-01-2014, 05:39 PM | #18 | ||
Whoa, this is heavy!
Seeing more and more articles in the truck mags about all the old school inters, bedfords etc. Definitely try get her running, give it a wash and try drag it to a regional truck show.....would gather a lot more interest if you wanted to sell it id say.
Liquid Silver 2002 AU III Fairmont wagon Le Mans Red 1990 SA Capri Turbo
07-01-2014, 06:54 PM | #19 | |||
Back to Le Frenchy
If there's anything I know, it's a v8 Ford so I'll give it a fair crack to bring her back to life.
I might have a good look and see what sort of rust is in it. Sent from my Nexus 7 using Tapatalk 4
07-01-2014, 08:40 PM | #20 | ||
64 Deluxe 4 door
You just dont seem to see many of the early F series around anymore. I got my truck licence in an F700. Had a 390 V8 and went like a rocket.
XM Deluxe FG XR50 BA Pursuit Ute |
07-01-2014, 09:30 PM | #21 | ||
not here much anymore
Get stuck in Russ. What a cool project.
2024 F150 XLT
07-01-2014, 10:53 PM | #22 | |||
Back to Le Frenchy
If I had the time and money, and more importantly the space, it'd be on.
Unfortunately I don't so no cool project for me. Shame really, as far as projects go this would be a relatively simple one. Sent from my Nexus 7 using Tapatalk 4
