Hi all
I have a series one au wagon on gas. When I have a cold start the car idles rough and the Whole car shakes for around 10 seconds then idles fine. Any ideas ? Cheers Mick |
XR6T BA 2002
having same problem on a eb 4 litre on gas
anyone keen to help us outtttttttt ????????????????????????????????????????????????? |
hi,
Me three, I had exactly the same issues as mentioned above, idled rough for the first 10 seconds or so ,then ran fine, even if I started it up straight away the issue would not be there So I decided to pull the fist solenoid off (the one right near the stepper motor) and unscrewed the brass fitting (don't know what its called) and all the parts , then notice the solenoid appeared to have corrosion through the centre of it , so I changed it with a spare one Everything works fine know ,so not sure if it was the solenoid or the cleaning of the brass parts or a combination of both cheers john |
#4 | |||
XR6T BA 2002
thanks john for the reply but um what solenoid am i looking for cheers |
