Old 07-09-2012, 08:17 PM   #151
XT302
Default Re: 10sec XTGT - photos and video
I spose
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2012, 02:39 PM   #152
XT302
Out at the track yesterday, could have been a really nice day if it wasn't for the wind
Comment from the owner "It feels like a grandma car at the moment"
Anyway 11.15 @ 127.43 on the 205x70x14 maxxis..... Really lean all day, at end of day may have found the issue, cracked/collapsed fuel line
You can't hit a home run every time I suppose
Old 09-02-2013, 09:38 PM   #153
XT302
So still having some fuel issues , plus not getting full throttle which couldn't be resolved at the track
Result from today's test and tune on the 205s
11.29 @ 125.90 , 11.02 @ 126.22 , 11.42 @ 124.83, 11.17 @ 125.86
Old 09-02-2013, 10:39 PM   #154
Windsor
11.02 @ 126.22 on the 205/70/14's & he is still grumpy. Cranky old ****.
Windsor is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2013, 02:09 PM   #155
Windsor
Sixty foot times for the runs were 1.863,1.757,1.921 and 1.831 for those that are interested. I'm sure Blocker will fix the throttle issue next time out. Although taking the p1ss out of him about it was nearly worth the poor mph.
Cheers,
Steve.B
Old 06-06-2013, 04:48 PM   #156
Windsor
We were at the track last night on the 205/70/14's. Complete waste of time as there was no traction in first gear at all. A best of 11.624 @ 126.66 (7.723 @ 99.71 to half track and a 1.988 60'). Was good fun with myself and XT302 telling the owner what a **** driver he is, but it did look slippery.
Cheers,
Steve.B
Old 16-06-2013, 03:09 PM   #157
XT302
At track update , fluffed a shift and thought he'd got out of it enough not to run a ten on some pretty average MT radials lol
10.76 @ 125.16 mph 1.574 60'
Old 16-06-2013, 05:49 PM   #158
^^ this guy ^^
Head Chooner
^^ this guy ^^'s Avatar
sold times mate
FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
FGX XR6 SPRINT 414/500 - Kinetic Blue [JETURBO]
Ngauge,Plazmaman,Venom,NPC,ATOMIC, listed stockist
...JD TUNING ADELAIDE...
^^ this guy ^^ is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 05:51 PM   #159
Roo2
Roo2's Avatar
Thanks for sharing. What shocks does he run.
Roo2 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 06:44 PM   #160
XT302
Pedders from memory
see this photo, they're white
http://www.ausmustangandford.com.au/...al-performance
Old 16-06-2013, 06:58 PM   #161
Windsor
Back from the track. Second and last pass went 10.70 @ 126.67 mph 1.614 60'. Car is out of fuel, again . 102.49 to half track and only 126.67 up top shows that.We pulled the plugs after the last run and it was definitely lean. The owner said as much as he could feel it nosing over top end. Always next time i suppose.
Cheers,
Steve.B
Old 16-06-2013, 07:10 PM   #162
Windsor
Pedders from memory
Definitely pedders mate, was stirring him about his suspension today. Be interesting to see the results if he spent money on upgrading it as most do.
Cheers,
Steve.B
Old 16-06-2013, 07:50 PM   #163
dieseltrain79
I'd say the fact it's leaving harder on decent radials means its not too endin like it used to ... There's nothing wrong with 24mph in the back half , to me it sounds almost spot on for half track and top end looking at the increments .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 08:15 PM   #164
Windsor
It should be going 127+ with that half track on MT Radials (and has done so a few times).
Cheers,
Steve.B
Old 16-06-2013, 10:09 PM   #165
greencapri408
greencapri408's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Simon is a worthy recipient, his willingness to share  knowledge here for Forum Members and his wealth of knowledge. He has made himself available not only through the Forums but allowing members to contact him by mobile as required
maybe the engine is going off
FORD because nothing compares
greencapri408 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2013, 10:18 PM   #166
Windsor
Maybe the plugs being white might explain the problem.
Old 16-06-2013, 10:33 PM   #167
XT302
valve springs check ok, as does leak down.
Old 17-06-2013, 12:57 AM   #168
Roo2
Roo2's Avatar
Thumbs up Re: 10sec XTGT - photos and video
Cheers,
Steve.B
Ye good results all the same. Do you know if its leaning out because of the fuel pump pressure / volume or jetting / air corrections.
I'm going to upgrade my suspension mainly to try and get some consistent times plus I'm hoping to be able to use full throttle in first. It would be interesting to see how his car would react to suspension improvements. He certainly gets good times on those maxis tyres.
Old 17-06-2013, 06:29 AM   #169
XT302
My guess the Holley 125 electric doesn't keep up in the real world, no issues on the chassis dyno.
the culprit in question
http://www.holley.com/12-125.asp
Old 17-06-2013, 08:49 AM   #170
Windsor
Mate it was on MT Radials yesterday.He certainly drives it very well on the little maxxis 205/70/14's. Be nice to see what your beast runs when you can get all the power down.
Cheers,
Steve.B
Old 17-06-2013, 08:59 AM   #171
greencapri408
a good quality pump is essential in a 10 sec car
old style vane pumps arnt geat, on paper they might look capable but only just
the issue is they are rated at free flow at 7psi it is substantialy less
then add street use and the pump wears in the vanes and your up **** creek
i run efi pumps in all my cars they can handle the volume needed at psi and maintain it thru the whole pass
tell your mate time to step up
Old 17-06-2013, 09:27 AM   #172
Windsor
The pump was recently checked by a mate at an aircraft mob. It was in good nick but flowed considerably less than advertised (600hp). That being said it was enough to support 127.98mph at over 3600lbs with a stock pick up location. It's probably time for an upgrade, how do you set your efi pumps up? Do you run return lines, pick the fuel up from the stock location, surge tanks, sumps etc.?
Cheers,
Steve.B
Old 17-06-2013, 04:44 PM   #173
greencapri408
run a magnafuel protuner 525 pump plumb a 8026 carb bypass in to it then a line to a dead head reg
the bypass returns into the tank in your mates case the filler neck
simple
these pumps are self priming so can be ran anywhere
Old 17-06-2013, 05:41 PM   #174
Windsor
simple
Thanks mate, i will pass it on.
Cheers,
Steve.B
Old 18-06-2013, 08:58 PM   #175
Roo2
Roo2's Avatar
Cheers,
Steve.B
Thanks Steve. I have watched a few videos of his runs & I agree he drives well. My next pass I'm hoping for a 10.1 / 10.2. I never use more than 60% throttle in first so fingers crossed I can address that while running the ET radials. Heaps of people have gone real quick on these tyres so I just need to set the car up right while not compromising my street set up to much where the car is used mostly.
Old 26-06-2013, 07:03 PM   #176
XT302
Forsale , check for sale section for details
