22-04-2013, 10:23 AM | #1 | ||
I am building a mk2 escort burnout car and want to know what is the cheapest way to convert to 5 stud front and maybe some slightly bigger brakes and if so how much does it cost or has it cost you as I'm building this car on a budget
22-04-2013, 12:53 PM | #2 | ||
Both UPC and hoppers stoppers do A 5 stud front end...or perhaps should say they don't do a 4 stud!! try there. as for the rear end are you upgrading brakes of staying with drums. That might determine what can be done.
JP |
22-04-2013, 01:36 PM | #3 | ||
24-04-2013, 07:13 PM | #4 | ||
I did the UPC kit for the front and Hilux diff in the rear. 5 x 114.3 all round which increases rim selection exponentially. You have to run minimum 15" with UPC kit though.
I have a spare kit at home if you are interested. You can have it for $600
May the boost be with you! |
25-04-2013, 11:42 AM | #5 | ||
600 is a little more than I want to spend really but thanks anyway ill keep looking into it
28-04-2013, 04:23 PM | #6 | ||
Hey Mr Turbo esky, I'm doing the same conversion off what model car have you found to get wheels with the closest offset?
G |
