It Never Ends
i have a 96 Ef GLI and having problems with the rear demister, the fuse is fine but when i push the button nothing happens, is there supposed to be a light behind the button or a light on the dash or something, even replaced the button is there some common fault for these that i should be looking for?
check the rear window and see if the plugs are plugged into the points on the rear windshield sometime they fall out.
It Never Ends
yeah checked that, its all good, might just get an auto elec to look at it
:D:D
could just be the switch mate change the switch
Cheers Grant |
It Never Ends
yeah mate went to wreckers and got new switch nothing changed... is there ment to be some sort of indication that its on? light on the dash or in the switch or something?
Just Cruzing
might be your lines on the rear window are broken check that, and test the power on the switch end and the window end may not be getting the power other wise ya got me.
Dark Blue 96 EL XR6 MOD'S Herrod Extractors & Redback exhaust lowered Au xr6 rims Successful Trades with:BradensEBxr6, snypereb, EDXR6T, ORSMF6 _______________________
yeah, i thought that the yellow lamp was supposed to light up when the demister comes on.
Hamish ![]() ED, Lowered Lovell Springs, Monroe GT gas shocks, SAAS Racing Buckets, SS Lab Sound System, Carbon Fibre Wheel, Full Sports Exhaust System. |
It Never Ends
is that in the dash or in the switch?
There should be a light on the dash that lights up. When you turn on the demister, you should hear a relay click in the fuse box. If you cant hear that it could be the relay. Check for voltage at the switch as well.
It Never Ends
thanks mate thats what was confusing me i just had no indication if anything was on,will check the relay tomorrow
i know its a old thread but i have the same problem excepte my econ light comes on
phat ltd in the making very lowly ![]() ![]() ![]() |
#12 | ||
it sounds like your demister switch is plugged into the wrong plug?
sometimes the plugs get swapped around behind the demister switch, there is usually a spare plug there, clipped to the back of the switch surround. this is for bench seat models for the economy/normal mode for the trans. they dont run a console so have nowhere else to put the switch. the dash looms suit a few different models/options. and the worst thing too with the demister not working is you cant program new remotes for your car.
Money Talks, but all i ever hear is it saying Goodbye!! |
#13 | |||
i swaped it around and i can hear the realy clicking but no light comes up on the dash
#14 | ||
sounds like you have a blown globe,
is the demister working now?
#15 | ||
not sure if it does yet i will wait for either winter or when it rains
