Carried out this job today and thought i would do another write up for those people that are interested.
First i jacked up the car and put it on stands, next thing i did was crack the adjusting nut. ![]() Then cut the cable tie that holds the boot to the tie rod, this enables you to twist the tie rod. ![]() Then undo the top retaining nut. Split the ball joint with the ball joint removal tool ![]() Undo the ball joint off the end of the tie rod, ![]() check the old one against the new one to make sure it has the same thread and length etc. ![]() Install the new part back on the rack end and screw it on as close as possible to where the original one was ![]() tighten the top lock nut and put in the split pin if its not a nylock ![]() Tighten up the larger adjusting nut (22mm) grease the nipple and take the car for a wheel alignment, but i might try this myself on the weekend if the rain ever holds out! Cheers Ben
6.7.2011 |
Escort MkII 1977 2.0L
Nice writeup and photos Ben.
Looks like a few other rubbers might need replacing soon. |
The link pin bushes are no better than the ones on mine, but mine has more cobwebs underneath too.
