27-12-2011, 10:15 AM | #1 | ||
Hey peoples , Just installed 1 of these from ebay . NON Genuine item i know , but its failed in les than 1 hour . Wont hold pressure and spews coolant out of the neck that the cap Sits on .
Seller is Located @ Smithfield , will be paying them a visit . However it leaves me needing to go to the wreckers today to chase one up as the wife needs her car fo the kids . Anyway , just a bit of buyer beware i guess , or im unlucky
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
27-12-2011, 11:47 AM | #2 | ||
Are you sure the pressure rating of the new cap is correct, or maybe you could use the old cap on the tank.
Historically, the main problem with AUs venting coolant has been the cap! Cheers |
27-12-2011, 02:19 PM | #3 | ||
Bugger!
+1, make sure the rad cap's good first
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
27-12-2011, 04:30 PM | #4 | ||
Stroking it...
+ 11tynine the cap
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
27-12-2011, 08:41 PM | #5 | ||
Got a link for it mate? I also purchased a non genuine off fleabay and it's all good. Using the old cap.
06/01 AUII XR8 |
27-12-2011, 08:47 PM | #6 | ||
But a B-series one in as a replacement ... I got from Macarthur Parts plus for about $40 with factory screw in cap. Worked a treat ... and clean.
I did have to change the lower hose out of the header tank as it is located differently ... but that was just a B-series one. One the shorter hose from the top of the header tank to the radiator needed to replaced with a longer one (I just got another thermostat housing to header tank hose and cut it to length)
29-12-2011, 11:14 PM | #7 | ||
New cap and old cap same thing . Always going to be a dud in a batch i guess , what can ya do .
New cap is rated at 135
30-12-2011, 01:38 PM | #8 | |||
rexnet
