rexnet
so my diffs died. im gonna give it a crack on my own. i have access to a hoist which will help. is it an epic job or is it do able? im going to have a 2nd car and so time isn't as much of a restraint as it could be. do i need any special tools?
RIP...
I did mine about 3 months ago, it's pretty straight forward.
Remove wheels. Exhaust tail piece. Tailshaft. Lower control arm outer bolts. Pry out CV's from diff. Diff bolts. Lower diff while holding out lower control arms. To fit new diff, do the above in reverse order. Took me about 4 hours, and I hadn't done one before.
. Oval Everywhere... |
#3 | |||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
![]() Heres the techo thread http://www.fordforums.com.au/vbporta...article&id=159 And a bit more here http://www.fordforums.com.au/showthr...light=IRS+diff No real problems as Sox says but it s easier with 2 people and if you have all FINGERS and THUMBS in working order ![]()
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
rexnet
sweettt!!! i've found a killer diff in sydney from a friend. so i'll get that when i get some $$$ together.
cheers sox n whoosh sounds like it should be alright then. probably can get a spare body to help me out and this time shall try hard to not destroy any digits or such. |
rexnet
and also. is there anything i should replace while i've got stuff out? any bearings or such.
RIP...
Not really, check the CV boots, tailshaft unis, but it's probably all ok, otherwise you might have noticed anyway.
Maybe even have a glance at the gearbox extension housing seal.
#7 | |||
rexnet
#8 | |||
RIP...
Takes all of 5 minutes, and $10 or so.
rexnet
Sic will do that. Did you need any special tools?
Critical Thinker
I doubt it special tools will be needed. Just a time consuming job to do and no doubt a heavy one. Just don't rush the job, and check and recheck everything once the new one is in. You may need to refer to the manual for torque settings of some things, but should be straight forward.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
RIP...
I can't really remember, but I don't think so.
#12 | ||
rexnet
![]() What is this ring. Does it need replacing or do I bend it in or what? |
#13 | ||
RIP...
Leave it on, doesn't need replacing.
It holds the axles in.
#14 | ||
rexnet
Sweet
