I'm replacing welch plugs this weekend which means I'll be flushing my cooling system. Should I refill with the motorcraft premixed coolant from ford, and only that, or is there something else that works the same/better?
Thanks. ![]() |
You can use any of the green ones to the coolant manufacturers specs - some are pre-mixed & some are concentrated
Just remember to change every few yrs
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
yep as FTe342 said , I personally use NULON coolant/oils there top shelf without the price tag
XC GS OLD SCHOOL MUSCLE ![]() Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
#4 | |||
![]() http://www.nulon.com.au/product_group/Cooling_Systems/ Which one do you use? |
Flairs - Truckers Delight
is it green? use it then.
a decade old car don't care what brand coolant you use.
slightly off topic, but what is the difference between the green ones and other colours?
-Tim |
#7 | |||
#8 | |||
I don't know about other pre mixes but I know motorcraft coolant is pre mixed with demineralised water
[SIGPIC][/SIGPIC]
#9 | |||
VFII SS UTE
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
if it has green in it before put green back in it, as long as it has corrosion inhibitors it should be ok, i read an article on cooling systems and they went into great detail that you should`nt put green in after red unless it has a very very very thorough flush and flush and a chemical clean, from what i can remember, the red stuff leaves some residue that reduces the performance of the green stuff.
And never use tap water !
#12 | ||||
#13 | |||
And the effects of using tap water is that the coolant is fighting the impurities in the water rather then corrosion in your cooling system. so basically reducing the effective life of the coolant. Hope this helps Cheers Jason
WANTED: MOMO Metallic blue steering wheel and Manual gearknob! PM Please!!
Stevo _____________________________________ 05/2000 AUII XR6 5sp|Pacemaker 4480 Competition Headers|Lukey catback|Tickford Azzuro's|Impco LPG Conversion |
#14 | ||
not here much anymore
Tectaloy gold in my xr8 and very happy with it.
RAM 1500
#15 | |||
The stuff that leaked onto my driveway was reddish-brownish but that may just be rust... there's a fair bit of "mud" that came out when I flushed it. Nulon's web page recommends to use a radiator flush to help remove all traces of the old coolant, but I'm concerned that the flush may work too well, and dislodge a spec of rust here, a bit of gunk there, and start leaking... I can replace the radiator if need be, but given I've spent about $1400 in maint & repairs on this car recently I'd rather not! |
#16 | ||
Lost Boost Gained Class
get a bottle of the GREEN NULON concentrated stuff 5L one poor 1/4 of the bottle in and top up with water (i juse tap water) always worked for me and never had a issue Fingers crossed
2006 BF Fairmont Ghia
2001 AU Falcon |
#17 | |||
There's plain tap water in there momentarily but I'll be flushing the system today (twice) then using the nulon concentrate mixed with demineralised water. |
#18 | ||
I replaced the thermostat and gasket too, I've noticed the engine gets to operating temp more quickly... eg when I used to drive from home (cold) to my daughter's school, the needle had barely moved into range by the time I arrived... now it's sitting at "O" in NORMAL halfway into the trip. That's got to be better for the engine since most of my trips are short.
The old thermostat had flaky black stuff on it, I'm not sure if that's hardened coolant gunk or failing paint? The new one was bare metal. |
#19 | |||
sorry spelling error 3/4 well jsut a tad over
2001 AU Falcon |
#20 | ||
3/4 still sounds too low if you want the recommended 33% concentration... in a 16L capacity system that's only 23%. Even the entire 5L container is a touch below the recommended level (31.2%)
Flushing doesn't completely empty the system so maybe you're thinking the capacity is less? |
#21 | ||
I read yesterday that EA-EF use the red coolant, while the AU uses green. Judging by a couple of stains that remain from long term minor leaks I'm starting to think that my AU may have had the red stuff in it, which isn't the correct type...
Unless the Motorcraft stuff is red? |
#22 | ||
Falcon Unbelievable!
I'm using the Nulon Red, from what I've read the Nulon Red is specifically for cars with an Aluminium radiator which my AU1 has.
/shrug had no issues so far with it,but eh it's Nulon of course it's gonna do the job well. Chris |
#23 | ||
i've never seen a falcon with red coolant, e-series/au or otherwise
this is the question i ask myself when i think about coolant. is there rust in it? no. does it say on the O for NORMAL all day long? yes. therefore? DO NOTHING.
#24 | ||
when i checked the coolant chart at motor mate recently it said to use the red coolant for an au series 2 fairmont v8
#25 | ||
ST fan
Whilst we are talking about coolant, how are you supposed to dispose of the old stuff?
After changing the coolant in my bike a few weeks ago i realised i didn't know what to do with the old stuff, which is now sitting in a bottle in the shed. Oil has never been an issue as we have an old 44gal drum at home to collect it. I plan to drop the coolant out of the AU soon but obviously it holds quite a bit more than the bike does and i'll need to dispose of it. Cheers.
2013 Focus ST in TANGERINE SCREAM 2003 Focus Zetec in COLORADO RED
#26 | ||
never leave coolant out where your pets can get to it, im not sure about cats but its deadly to dogs very bad stuff.. i know its common sense but never can be to careful
#27 | |||
i don't think it'll kill anything especially not if you dilute it by hosing it afterwards
#28 | |||
When in doubt, GAS IT!!
Um, I don't think that's quite right. I changed my coolant one day on a patch of grass where I used to live in NSW and the grass died. The patch was still dead 12 months later. Bushbasher
