12-03-2011, 12:45 PM | #1 | ||
Next upgraded Mk1 Leopard
Can you 'turn off or disable the DTE warning sound.
UK
12-03-2011, 01:03 PM | #2 | ||
All Bran = Regular Member
I've found that the sound stops when I put petrol in... j/k
If you could find the sound source you may be able to disconnect it, I don't know tbh. |
12-03-2011, 01:48 PM | #3 | ||
When i had IDS hooked in to my SR i didn't see anything to disable it. Just coolant, washer bottle etc.
That's a low series cluster though.
AU XLS. |
12-03-2011, 01:54 PM | #4 | ||
meh.
you could always remove the speaker on the rear of the cluster for it..
but then if you leave your lights on you'll forget about them
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
12-03-2011, 05:56 PM | #5 | |||
UK
12-03-2011, 07:09 PM | #6 | ||
this simple circuit will fix the problem it will make the fuel gague read full when you are on gas the resistor should be 1W the relay just a SPDT to act as a change over relay the sender wire just needs to be cut and the contact wired so the sender is connected when the relay is not powered up the resistor could be smaller if you wish 47 ohm will give you just over 1/4 reading
[SIGPIC][/SIGPIC]
Everyone starts off with a bag full of luck and an empty bag of experience. The trick is to fill the experience bag before the luck bag is empty. "It is better to remain silent and be thought a fool than to speak out and remove all doubt." Start a new career as a bus driver Rides: FG2 XR6 stock at this stage but a very nice ride xc 4 DOOR X CHASER 5.8 UNDER RESTO Last edited by FGII-XR6; 12-03-2011 at 07:17 PM. |
12-03-2011, 08:40 PM | #7 | ||
just an after thought you could put a normally closed momentary push button so you can check the fuel while on gas just put it in the wire to the LPG solenoid
[SIGPIC][/SIGPIC]
12-03-2011, 10:42 PM | #8 | ||
Flairs - Truckers Delight
i just stab the stalk a couple of times, stops it after only one or two triplets
13-03-2011, 10:52 AM | #9 | ||
When in doubt, GAS IT!!
Um, unless you have an electrical issue that causes it to sound all the time wouldn't it be easier to just put a couple of litres of petrol in it? You're supposed to run about 1/4 of a tank at all times anyway to stop the fuel pump chitting itself. Plus you need some petrol for cold starts anyway. I'm on gas 99% of the time as well and just run the petrol out every month or so and put in some fresh premium to help freshen up, (as it were), what's left in the tank.
Bushbasher
13-03-2011, 11:01 AM | #10 | |||
i do agree with you tho. i normally keep just over a 1/4 of a tank in mine for that reason, to keep the fuel pump working... oh and to stop the dte beeping at me, lol |
13-03-2011, 03:08 PM | #11 | ||
Miami Pilot
Cheapest and easiest fix for this would appear to be $15 worth of fuel.
13-03-2011, 04:25 PM | #12 | ||
Thanks to all for the suggestions. I'm no auto electrican so thats out. I will have to keep just under 1/2 a tank of petrol as this level stops the bee bee.
UK
13-03-2011, 07:55 PM | #13 | |||
