Old 06-09-2007, 11:57 AM   #1
Auxr8hbt
AUII XR8 Ute
Default Au Ute Water Leak
My mate has an auIII ute and it leaks water near the bottom of the steering colum when it rains. It is obviusly running down from the firewall or windscreen but it doest seem to stand out.
Any leads???
AUII XR8 UTE........std but big rims!!
Auxr8hbt is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 02:29 PM   #2
howesy
howesy's Avatar
Windscreens are a known problem, pay the 20 extra and get O'briens to pull it out and re-seal. they give a lifetime waranty on leaks.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 03:23 PM   #3
kenz
BOSS Pilot
kenz's Avatar
Common problem with the AU. Its most likely coming through the firewall somewhere. Mine does it, and Ive heard of so many others that do it aswell
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 10:00 PM   #4
Auxr8hbt
AUII XR8 Ute
Thanks.I will tell him he Might as well get the windscreen resealed as a starting option.
Old 07-09-2007, 08:16 AM   #5
Sledgehammer
Sledgehammer's Avatar
Yep mine does it as well.
Sledgehammer is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 09:18 PM   #6
VCT_XR6_UTE
VCT_XR6_UTE's Avatar
yep mine does it aswell, gives me the sh**s, but as it hassnt rained much dont notice it, still pain in the but tho
VCT_XR6_UTE is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 12:09 AM   #7
loxxr6
XB in parts...
loxxr6's Avatar
Is it a manual ?
If so, they're known to suffer from cracked pedal boxes. The firewall can also crack. Get these two bits checked out.
I had mine fixed a short time back.
Daily Driver 2019 Ford Escape...looking for XR6T's.
loxxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 12:42 AM   #8
Firebell AU3SR
Firebell AU3SR's Avatar
yep my Au3 sedan has just started to leak water from under the dash above the ecu near the duct on the passenger side when it rains heavy.The water drips on to the floor mat when im driving.Any ideas.
Firebell AU3SR is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 04:06 AM   #9
blue terra
au=gold
blue terra's Avatar
How much water do people get in just for curiosity. And where's a good place to seal it. Cos my drivers side fills up pretty nicely
blue terra is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 10:32 AM   #10
LPGUTE
LPGUTE's Avatar
yep my ute leak aswell keep driping down on my foot near the clutch pedal
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 10:34 AM   #11
The Monty
Just slidin'
The Monty's Avatar
When I go around sharp lefts in the rain, I get a dribble on my foot. Always freaks the hell outta me, but to answer the question, its normal, just an AU thing.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 10:37 AM   #12
Lukeyson
Right out sideways
Lukeyson's Avatar
yes my ute does it too, sedan doesnt though
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 10:49 AM   #13
kenz
BOSS Pilot
kenz's Avatar
Originally Posted by loxxr6
Is it a manual ?
I know for sure that mine isnt a cracked pedal box as I recently put a brand new one in about a month ago and it still has water getting in
Black BAII XR8 Ute
Old 09-09-2007, 01:10 PM   #14
blue terra
au=gold
blue terra's Avatar
Sad thing is there seems to be too many common problems With the Au
Old 09-09-2007, 01:18 PM   #15
gfanga
my au xr8 manual sedan does it too. Might have to check the pedal box....
gfanga is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 11:45 PM   #16
mr302xd
Formerly MR BAXR6t
mr302xd's Avatar
yea just noticed the same problem with my series II
mr302xd is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 06:15 AM   #17
lethal_xr8
lethal_xr8's Avatar
my Au xr8 does it, comming from up under the dash near steering somewhere. not near the pedal box, really annoying
lethal_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 11:54 AM   #18
womble101
womble101's Avatar
Add two more to the list. A AU2 XR6 ute and AU2 XR8 rebel. Both man. Only leaks under acceleration on to our right foot, from above the brake. Have looked but can't find the leak. will chack the windsceen and pedel box later.
womble101 is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2007, 01:09 PM   #19
loxxr6
XB in parts...
loxxr6's Avatar
If it's not the pedal box, it's could be
- a crack in the firewall,
- a drip where the wiring goes thru (the firewall) and the rubber gromet thing is loose (causing leaks) or
- the heater hose leaking.
These seem to be the most common AU water related problems that I've heard about.
Old 11-09-2007, 09:34 PM   #20
Auxr8hbt
AUII XR8 Ute
Il get him to check every area mentioned and try and eliminate it.
Thanks.
Old 10-03-2011, 06:45 PM   #21
reefgreen
so have any of you had the problems fixed
reefgreen is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 06:58 PM   #22
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
http://www.fordforums.com.au/showthread.php?t=11220972
This should hopefully solve ur problems, i did the same to mine
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2011, 07:44 PM   #23
reefgreen
thanks for that looks like that might b the problem will try it and let ya all know thanks again
Old 12-03-2011, 02:29 PM   #24
XR6SQ
My ute used to leak water on my feet when it rained heavy.
Took the advice of the above link and haven't had the problem since.
AU111 XR6 Ute, VCT, Leather, Manual.
XR6SQ is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 03:16 PM   #25
reefgreen
its has worked for me too thanks again hope i can help u out next time
Old 12-03-2011, 05:16 PM   #26
Cadge
Agree with the last link. Followed it and now can get into my car in winter without a half inch of water in the footwell...
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 12-03-2011, 10:46 PM   #27
b2tf
not here much anymore
b2tf's Avatar
I actually did mine yesterday and it worked a treat.
RAM 1500
