Just wanted to say thank you to all of those that posted on these forums in relation to idle issues. I just spend all of four hours replacing my inlet manifold gasket and this solved the problem!
Thank you! |
Sly like a G6
Yep, it'll do the trick. Apparently it's common for the gasket to leak around cyls 1 & 2, but mine was leaking at the back, around 5 &6.
Now I have a sweet, smooth idle down to 600rpm that is only belied by some slight whine from the blower :-)
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
![]() Join Date: Oct 2006
Good news.
regards Blue |
