15-01-2011, 11:43 AM | #1 | ||
What is the simplest way to replace a fuel pump in an au1 wagon. Do you drop the plastic tank or is there a round inspection opening in the floor?
15-01-2011, 01:57 PM | #2 | ||
meh.
when the fuel pump was replaced in the AU, the tank was dropped....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
15-01-2011, 07:39 PM | #3 | ||
Thought so,but when I ruined a pump 5 years ago I had to drop the lpg doughnut tank on to a tranny stand to move it 75mm sideways to unbolt the plastic fuel tank. Even on the hoist it is a **** of a job and takes a long time.It would be great if there was a removal cover in the floor above the tank and it would be a 5 minute job. 125mm hole cutter coming up methinks!
15-01-2011, 07:43 PM | #4 | ||
meh.
well it was done within 1hr max... and the AU has the regular petrol tank and a doughnut gas tank that goes exactly where the spare wheel use to go...
although having a hoist helps
12-02-2011, 02:23 PM | #5 | |||
Any help appreciated - any description/photos etc would be most welcomed. Many thanks - Greg. |
