Posts: n/a
Can anyone help with loading the security code. I have the code but the Radio display now always shows 'Err'. I originally got the 'Code' display when the battery was replaced. But, since I loaded the wrong code a couple of times, I now keep getting that darn 'Err'. I did leave it overnight & tried this morning 0 no good. Tonight, I disconnected the battery for varying periods up to 30 minutes & tried again but still no go. Do I just wait for another 24 hours or what? Otherwise I will have to go to a dealer !! (The AU has the "Prestige audio System")
Thanks in anticipation.. ![]() |
Audi S3
have you unplugged the radio from its loom and plugged it back in. try that.
i think we did that to my mums car. cause its had several replacement stackers and we mix up the codes sometimes. now sorted.
Posts: n/a
Thanks HLC, that was fast ..I'll try that - I endevour to get back with the result. Cheers
Miami Pilot
![]() Join Date: Jan 2005
That's not going to work - disconnecting the battery has the same effect as unplugging the loom (ie no power to radio).
What you need to do is to turn the car to the "On" position (ie accessories on, engine off - where the radio would normally turn on), and turn the radio on so the "Err" displays and leave it like that for at least 45 mins. Then it should go back to code, and enter the code in carefully. If you get it wrong again, you need to do the above procedure but you need to leave the key in for a longer period of time.
The Hammer: FG GTE | 376rwkw | 1/4 mile 11.793 @ 119.75mph 1.733 60' (4408lb) 1 of 60 FG MK1 335 GTEs (1 of 118 FG Mk 1 & 2 335 GTEs). Mods: Tune, HSD/ShockWorks, black GT335 19 staggered replicas with 245 & 275/35/19 Michelin Pilot sport 5s Daily: BF2 Fairmont Ghia I6 ZF, machine face GT335 19 staggered Replicas with 245s and 275s, Bilsteins & Kings FPV 335 build stats: <click here> Ford Performance Club ACT |
#5 | |||
Audi S3
Do wat JC says, leave the key on ACC for atleast 45 minutes then try, dont drive the car in this period or touch it however!
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
#7 | ||||
Miami Pilot
they call me Tibbo
it might take more than 45 mins.. THe error message flashes longer for every time the code has been entered wrong. It might take 4 hours if you have entered the wrong code 5 times for example..
AULTD
I had this problem with the LTD ( premium sound system ) the first time I changed the battery. When it asked for the code I carefully put in the number that Ford provided in my service book. I then received the dreaded ErrOr. Waited 5 Mins and Code came back, put it in again and the same thing., this time waited 15 mins and tried yet again with the same result.
I rang Ford and they said even a dummy can put the code in correctly, so down to Ford I went to find a dummy ( plenty of them around apparently ). By the time I got there the ErrOr had disappeared. They said $10 to put in the code, I thought a bit expensive but I wanted the stereo to work so I agreed. They went to their computer and punched in the cars details and it gave them the code ( exactly the same as the one I had ). Out comes the service guy ( yes I found a dummy ) and types in the code. ErrOr comes up again. He said the code must be wrong for the unit and then has to take the radio out to get the serial numbers off the back of the unit ( lucky they come out easy sometimes ). He went back to his computer and typed in the details and it gave him a new code number. He couldn't put it in because the unit was showing ErroR so didn't charge me the $10 as it was now a warranty item instead. I had to wait a couple of hours for the code to show again but the new code did work. Worst case scenario is pay $10 to Ford for a new number |
Posts: n/a
PM the user SIDO. Give him your SIDO number and ask him really really nicely for the radio code.
Edit: Can't find the user. gotta check my PMs to see the username edit 2: PM MR_SIDO with your SIDO and ask really really nicely. |
#11 | |||
Irregular Member
#12 | ||
Miami Pilot
Thanks - but you knew what I meant.
#13 | ||
Posts: n/a
Thanx JC & others. Leaving the key turned to the accessory position (1st stop) worked. I appreciate all your help guys!. Now my wife can spend some time & tune it in again.
#14 | ||
Irregular Member
It's always a nice feeling when the radio comes to life after you tentatively try to enter the correct code :1syellow1
She mostly takes
![]() *** Wheels magazine COTY 2004 *** I usually get: Mitsubishi Magna ES (TL 2004) *** Wheels magazine COTY 1996 *** |
#15 | ||
Posts: n/a
damm i entered it 3 times incorrectly tonight.... stupid code number waiting wating waiting.. and its cold out tonight... 45 mins hey, hmmmmm started @ 9:06pm..
#16 | ||
Posts: n/a
just went out to ute, and code was showing up, so 1/2 hour tops yay!
#17 | ||
So you are saying that you dont need to know the code to reset, simply leave the key in the ignition position and let the computer acknowledge the key and the code appears? Just bought our 2nd AU and no owners manual/no code!
#18 | |||
not here much anymore
Example - put code in, code is wrong delay try again, get code wrong again even longer delay and so on.
RAM 1500
#19 | ||
Thanks,guess I'll have to get the code from Ford.
#20 | ||
My code is 732, how can i enter in ford falcon 1999 model car i can see numbers frm 1 to 6 how can i enter 7
#21 | |||
Miami Pilot
#22 | ||
hi how do i contact asl (site sponsor) new here and have a premium sound system i need a code for thanks guys
#23 | |||
Miami Pilot
#24 | |||
#25 | ||
looks like i may have the radio code have to wait until monday.oh well heaps to do just brought a el wagon and a (el xr8 very rusty) putting all the xr8 stuff into the wagon. once that is done need to finish the xh v8 panel van conversion
#26 | ||
Mr LTD
Hi guys
Just brought a old 1989 DA LTD. And the car had a flat battery. So it has lost the Radio. Just wondering that now it's 2018 that anyone knows how to find the codes . Ford say it's to old for their records. Can any one help please or know someone that can. Cheers Last edited by brianhog59; 09-10-2018 at 12:58 AM. |
#27 | ||
How put the radio code on my ford territory 2012 model
#28 | ||
