11-02-2010, 01:57 AM | #1 | ||
PEPI69
Hi,
Cooling fans have stopped working - checked fuse not problem - fans works off battery - and I'm not that bright, would appreciate some advice. Thanks
aims to please................. |
11-02-2010, 02:02 AM | #2 | ||
have u checked the relay ?
there are 2 iirc in the fuse holder if u turn the fuse holder cap upside down u should see a diagram telling you what relay's and fuses are what bit hard to explain how to check relay's best bet is go get 2 new ones should be about $20
wtf am i doing here! : : : |
11-02-2010, 08:31 AM | #3 | ||
XR6
As Disco frank has said, if the two 40amp fuses are ok...
Check the relays??? There are three of these!!! Two 4 blade 40amp relays white in colour & one 5 blade 40amp green relay. |
11-02-2010, 12:32 PM | #4 | ||
PEPI69
Thankyou for your prompt response gentle men - actually that would have been my next question 'which relay N#?'......
in the immortal words of Meatloaf...."2 out of 3 aint bad"...... :togo: thanks
12-02-2010, 01:10 AM | #5 | |||
hmm i thought they went from 3 relays in e series down to 2 in the AU being a long time since i looked LOL
12-02-2010, 10:09 AM | #6 | ||
Hmmmmm Mulberry....
Make sure they are plugged in!!!!!
Might sound silly, but they come loose. |
12-02-2010, 10:38 AM | #7 | ||||
Captain Malcolm Reynolds
Might be a long shot - isn't there some sort of temperature sensor that kicks them in when the engine gets to a predetermined heat? Any chance it could be that sensor if its not the relays or fuses?
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car) Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla Quote:
12-02-2010, 04:31 PM | #8 | ||
Sensors to computer, computer controls fans. Hi and low function fans run in series.
My high was working low wasnt and engine was over heating. Replaced fans $100 from wrecker. all ok now.
Au Falcon Ute S2 2001 Lowered on Kings with Bilistien Shocks all round 2.5inch cat back K&N Panel Filter FG XR6 17" Rims 245/45-17 tyres XR6T Snorkle BA front Caliper Conversion 300mm With Bendix Heavy Duty Pads Tow bar Transmission Cooler |
14-02-2010, 02:14 PM | #9 | ||
PEPI69
Hi all,
took car to auto spark and he is stumped.......can't resolve problem - still not working. I was thinking, can I just hardwire the thermo fans to the battery and let them run when ever the car is operating, even rig a toggle switch back to the cabin. I don't see why this would be a problem. My main question is do these thermo fans for au2 run at different speeds or on/off. I think the hardwire option is the best way - cost enuff already......:(
15-02-2010, 12:35 AM | #10 | ||
[QUOTE=illusivedreams]Hi and low function fans run in series.
QUOTE] Quoting myself. They are a 2 speed high and low : Again run in series. Fom what I can understand you can loose low speed and high still works. So check that you have both/// Im not sure how its wired. Alternatively come to the wreckers and give the $20 and borrow the fans for 5 minutes there are only to bolts holding the fans in place and bottom slotts in. See what happens you might be lucky./
15-02-2010, 08:19 AM | #11 | ||
XR6
R u blowing fuses for the fans... check fuses again!!!
Then.... Check with a multimeter or aligator clips with a globe at the plug before the thermos. That way you can check for current when the low speed thermos r suppose to kicks in... just above operating temperature, between n/o on temperature gauge. When the a/c is turned on, the thermos should come on straight away. |
15-02-2010, 12:47 PM | #12 | ||
Check the 10A fuse in the dash, fuse 7 on the top row from the left
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
