I was doing some research into the Pinto engines and found that they also came in 2.3L EFI (taller deck height) versions over in the states, some even EFI Turbo charged versions.
I kept looking around at later model OHC 2.3L and they continued making them all the way til 1999(maybe later) in the Ford Ranger. Under all the plastic tubing and such the engine looks very similar to the 2L pinto in the escort and i was thinking it could be a very very EASY swap for a late model, fuel injected, much more powerful engine. Much the same with the 2.6L Mazda Bravo engines too. Has anyone else looked at these? Anyone know if it can be done? I'm not sure what sort of work is involved but it seems like it could be a great and cheap reliable upgrade.
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
Ute Forum Moderator
![]() Join Date: Dec 2004
Would have to be possible but not sure if ever done here due to need to import engine (there goes cheap?) - most people going that far would be looking at a DOHC engine instead. Don't think the Mazda engine is related (making mounts/bellhousing harder) and also it is quite a heavy engine as would a tall-deck Pinto be.
Better option would be to fit EFI from a Sierra on a 2L Pinto |
That can be very expensive though unfortunately.
Rally Nut
you can get a 2.3 l pinto from a sierra (UK), or try Esslinger in the states for some drool go fast bits for the pinto
The 2.3 from a sierra uses is the same as a pinto here so everything bolts up - maybe an aftermarket computer... Most people are looking at a Duratec or Zetec, late model, DOHC etc as they are getting fairly easy to get hold of now. The conversion can add up by the time you change the sump & other bits & pieces You can get 2.3 strokers done here, they do have a heap more torque, but not common anymore no real answers for you - sorry, but there are some many options these days |
Wow your now joking about the Drooling...
#6 | |||
Ute Forum Moderator
#7 | |||
http://www.turbosport.co.uk/showthread.php?t=134573
1977 MkII Escort Ghia. 2006 MY07 Subaru Liberty GT Spec B wagon. my photo blog; http://www.jamesruff.net |
Rally Nut
cheers - I stand corrected, I had seen articles from old Performance ford mags (UK) that had the motor in MK1 escorts and had been told that the crank fitted into a 2ltr block
I will have to go & re read David Vizards book again as he mentions Esslinger etc in his 2ltr Pinto book! |
#9 | |||
Rally Nut
I know Esslinger do stuff for the Pinto - we have spoken to them about getting some rods
I was curious to go back to Vizards book to see if he mentions the 2.3 Lima or if he is just talking the Pinto, I got given the book for my 21st I think - Its gathered a lot of dust since then - lol |
MkII Escort
Ive been looking into these engines, and they are not the same.
So you would be looking into a full conversion. Tho i dont think it would be all that hard. The main thing thats making me think twice about this is that the 2.3efi turbo weighs 204kg and the 2L pinto weighs i think ~150 But what makes it look good is in the thunderbird turbo coupe has 190rwhp stock on 12-14psi. So the internals of this engine must be pretty strong. And in the mustang the engine is mated to the ford T5 gearbox, you know the same box out of the falcon =) nice and cheap and strong. The advantages of this ino is that i would be getting a powerful turbo engine cheaper than the likes of turboing a zetec and its still a blue oval engine. p.s Thunderbird Turbo coupe weighs 1.5tonne and does 0-100 in 8sec. put the engine is an escort lets say 1tonne think of the fun. |
#12 | ||
From the Futura
They're heavy iron head engines. Maybe a Mazda FE from a telstar is a good escort swap.
#13 | ||
Only problem then is converting the engine to north/south setup which requires cooling system changes, custom mounts, probably customising the crossmember etc.
#14 | |||
just more info....quote from wikipedia
1628 Escort Project Thread 67.3 RWHP - Paramount Performance Dyno DJ Automotive Tuned with proper jets http://fordforums.com.au/showthread....4&page=1&pp=25 |
