Old 29-09-2008, 04:09 PM   #1
PaDDy555
Question 1.8 dohc engine? (WA)
hey, im new to the forum, i've got a 1978 mk2 escort with a dieing 2L pinto :
so i was wondering if anyone had or knew of a 1.8 dohc engine for sale?
once i have it and have the money i plan to work it a bit and put it in the eskie (hopefully before the current one dies)
...Life is divine chaos...
2008 FG XR6T sedan
Tint, XYZ coilovers & debadged
"We don't need to visit madhouses to see disordered minds; our world is the madhouse of the universe"
PaDDy555 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 04:38 PM   #2
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
I assume you are looking for a Zetec or Jap motor?
1965 Ford Anglia
1980 Ford Escort RS2000
2006 Mazda SP23
2012 Ford Focus ST
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 09:42 PM   #3
PaDDy555
nah the 1.8 DOHC that came in the earlier model escorts.... was planning on boring it to 2L and then work on it some more
2008 FG XR6T sedan
Old 30-09-2008, 11:06 PM   #4
PaDDy555
i've found an SR20DET for sale but i was hoping to try and stick with originalish parts and not go ricey.. but then again its probably cheaper to go for the SR20DET for a good power/money ratio instead of rebuilding a 1.8
2008 FG XR6T sedan
Old 01-10-2008, 12:09 AM   #5
RSgerry
RSgerry's Avatar
do you mean a BDA???? good luck finding one. if you do, then expect to pay BIG bucks to get it and even more to modify it. they also had a bit of a reliability issue...
1965 Ford Anglia
2006 Mazda SP23
2012 Ford Focus ST
Old 01-10-2008, 02:07 AM   #6
PaDDy555
hmmmmm well i guess that idea is going out the window :
that SR20DEt is starting to look good about now.....
2008 FG XR6T sedan
Old 01-10-2008, 07:00 PM   #7
PaDDy555
how much would i be looking at for a YB 2L 16valve turbo?
2008 FG XR6T sedan
Old 01-10-2008, 10:13 PM   #8
RSgerry
RSgerry's Avatar
i think you would be looking at close to 10k for a cossie, but you would need to check that. have a think about the Zetec. twin cam, capable of an easy 200 hp (same as a stock cossie turbo) and apparantly still very driveable. your best bet would be to contact one of the experts in the field. I believe Escort Road and Race are good, and I use Racetune who have converted both Cossies and Zetecs.
1965 Ford Anglia
2006 Mazda SP23
2012 Ford Focus ST
Old 02-10-2008, 04:15 PM   #9
PaDDy555
cheers
2008 FG XR6T sedan
Old 14-10-2008, 11:13 PM   #10
Screamin TE
so the Zetec you guys are talking about, is this the front drive engine from the Focus?
Screamin TE is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2008, 05:49 PM   #11
RSgerry
RSgerry's Avatar
there are conversion kits that will allow you to install a zetec, available from the UK.
1965 Ford Anglia
2006 Mazda SP23
2012 Ford Focus ST
Old 16-10-2008, 01:24 AM   #12
RS027
Perth XR5'er
RS027's Avatar
1.8L from a KH laser or similar mazda are also an option.
Ford Rallye Sport Club of WA; Member#64:
Barbagallo Short: 1:01.1779
Barbagallo Long: 1:12.4649
Collie: 55.90
K&N Gen2 57i CAI / 2XS RIP / Airtec Gen3 IC / Mongoose Dump Pipe / Outlaw 200cpsi Cat / Milltek Ultimate Race Catback / Whiteline 24mm RARB / Whiteline FALK / BC Racing BR-Spec Coilovers / RSR Rear Camber Arms / Ferodo DS2500 Pads F&R / Goodridge Braided Brake Lines / Elevate Torque Mount / DS MOD C / MkII RS Clutch & DMF / Quaife LSD
RS027 is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2008, 09:40 AM   #13
whooligan
whooligan's Avatar
No, you need to use the ones out of the mondeo.....Can't remember the reason why, but it has something to do with the ECU. Early engines you can use aftermarket ones, whereas the later engines it gets a bit more complicated......That why I like the pinto....KISS principal. :
whooligan is offline   Reply With Quote Multi-Quote with this Post
