Old 14-06-2005, 07:35 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default AU's running Pacemakers
Just a small request from the AU fraternity (sp?)....
Anyone running Pacemaker headers (PH4480 or PH4499), can you please post pics? I got some opinions about my ute, and just wanna see what everyone elses looks like.
Edit - Reason being is I wanna see the space the headers take up, and if I need to move my LPG converter to another spot...
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2005, 09:08 PM   #2
duaned
duaned's Avatar
go to this threadto see as to what they look like unfitted.( These are the PH4480 )
http://www.fordforums.com.au/showthread.php?t=10194
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2005, 09:12 PM   #3
jonbays
TL40 Wagon?
heres mine
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2005, 10:21 PM   #4
Stav
Smile
Stav's Avatar
Mice colour too!!
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 15-06-2005, 07:55 AM   #5
jonbays
TL40 Wagon?
Actually its the standard pacemaker colour. Not really my idea.
Its now als getting the mottled brown rust spots that seems to affect all pacies tooo : (
Old 15-06-2005, 09:40 AM   #6
TheSneakiness
Adapt or perish...
Thanks for that jonbays, that's what I was looking for.
And yes, I will have to move the gas converter, looking at that. F*ck.
Edit - jonbays, what's the length of the pipe I put a yellow line on? I *may* be able to get away with not moving it...
Carless
Old 15-06-2005, 02:04 PM   #7
jonbays
TL40 Wagon?
OK no. 4 pipe comes out from the exhaust cyl head face 22cm and actually goes up 2cm above the line of the exhaust bolt.
Its going to be a big problem I would think.
Old 15-06-2005, 02:07 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
Yea, that would smack right into the bottom/side of the Vialle convertor because those Vialle suckers are 3 inches wide
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2005, 03:58 PM   #9
TheSneakiness
Adapt or perish...
Is that what my converter is Racecraft?
Keep in mind it is aftermarket.
Edit - Found a pic. Don't worry about the black circle. The converter is on the left under the coolant container. I will take a better picture tomorrow morning.
Carless
Old 15-06-2005, 07:47 PM   #10
jezza1
yeh i have the same sort of setup as you except my gas convertor thingy is back more and probably a lil higher.. its more sorta situated behind the radiator resevoir, i think im just gonna be able to get away with it.. i think... by looking at the pics you guys have posted im pretty sure i should be able to to it..
jezza1 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 08:04 AM   #11
TheSneakiness
Adapt or perish...
OK. I went and took some more pics. And yes, my damn converter will get in the road. It's fuggin huge.
Carless
Old 16-06-2005, 08:36 AM   #12
Racecraft
they call me Tibbo
Racecraft's Avatar
ahh you have an OMVL convertor, they are 1/2 the size of the factory vialle convertors..
Easy enough to move it though, get the headers fitted and then find a new home for the gas convertor
Old 16-06-2005, 09:44 AM   #13
TheSneakiness
Adapt or perish...
Sounds like a plan. But ideally I want to move the convertor first and then put the headers in, just in case I need extra length on some pipes, etc...
Carless
Old 16-06-2005, 02:15 PM   #14
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
There's so much length in those pipes, would be a piece of **** to move it up and back behind the coolant reservoir. If you were super-keen, you could probably fab up a neat bracket and cover for it too.
Tibbo - are there any considerations when relocating a convertor? Do they need to sit level or be on a certain angle or orientation or anything? I know they need to be kept away from heat as much as possible...
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2005, 02:58 PM   #15
TheSneakiness
Adapt or perish...
I'll ring the gas mob Nick. May make life a little easier at the moment.
Carless
Old 17-06-2005, 01:02 AM   #16
Mechan1k
Mechan1k's Avatar
I couldn't get the Pacies fitted cos the factory converter was in the way .... so I just have a cat back system on ... damn ... I'd love to get a set of Pacies though on the ute.
