27-11-2007, 11:56 PM | #1 | ||
Over Thinker
2. rear wheel cylinders leaking badly.::: buy of the shelf
3. brake shoes need replacing. :::same 4. front brake hoses perished and need replacing.:::same bleed the whole brake system 2-4 you can do yourself now you can remove the lower control arms that means CV joints off the lower control arm bushes themselves have to be cut out with a hacksaw if original or pressed out take the lower control arms to pedders or other suspension shop fit the bushes to save a bit of labour
My car goes Brumm Brumm |
