Old 08-06-2007, 08:55 PM   #1
XR.Turbo
Spooler
XR.Turbo's Avatar
Post Low Level Outputs - BA Colour ICC
Hi Guys,
Just looking at you site and was hoping for a bit more info on the Low Level Output conversion you do.
  • What voltage are the outputs?
  • I gather there are 3 sets (Front, Rear, Sub?)
    Is there an option to still use the speaker level outputs for one channel and low level for the others?
  • What do you use for a trigger for an amp? (there is a mention on your site about this)
  • Any problems with noise etc, or does it just act like any other H/U with RCA outputs?
  • Any other info you can provide?
  • How much?
Sorry for all the questions
Thanks!
Chris.
XR.Turbo is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2007, 09:13 PM   #2
XR.Turbo
Spooler
XR.Turbo's Avatar
Sorry just saw the price on the web! my mistake :(
Old 09-06-2007, 12:13 AM   #3
WASXAMAN
XR8 Driver
I have had it done by ASL and I can provide you with some of the information. This information was provided to me by ASL.
I believe the maximum output is 1V. I am driving JVC power amps and the attentuators on the amps are about halfway.
I have Front L-R Rear, L-R and Subwoofer outputs. It all or nothing. If you want line out, the internal power amps are disabled.
The trigger is a voltage applied to the wire when the ICC is on. It works well with both my JVC amps.
As I have mounted the amps on the underside of the parcel shelf, I purchased good quality RCA cable with double shielding. I also used very good earthing including an addition each from the battery negative to the chasis. Result - no interference noise at all. You could say it acts like any other head unit.
Price - if you already have a colour ICC, then the conversion is relatively cheap. I think it is on the web site.
All the above information applies to the colour ICC. If you have the basic sound unit, I believe they can't provide a separate subwoofer output.
If you want any further infromaton contact Fadi at ASL Logistics.
fadi@asllogistics.com
I hope that helps
Good luck
WASXAMAN is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2007, 04:03 PM   #4
XR.Turbo
Spooler
XR.Turbo's Avatar
Thanks for the info Wasxaman, however I would have one comment.
Going by the above, I'm assuming you have the amps upside down on the parcel shelf. If this is that case I would re-consier that option. Amps have a heatsink on the top side for a reason and I would guess that you would render your amps prone to more heat and diminshed response resulting from the heat rising?
Anything to ad Fadi?
I thought that was the point of this section of the forum so all people could see the response?
Thanks Guys!
Chris.
Old 14-06-2007, 05:36 PM   #5
FADI75
Sponsor
Thanks Guys!
Chris.
chris
you can call Karl at ASL anytime to discuss the low level conversion. 0397991444.
cheers
fadi75
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
Old 26-08-2007, 08:58 PM   #6
FPV 204
Shockwave
FPV 204's Avatar
Since having my unit converted to low level outputs, when ever i play a DVD the colour screen now has a pink tinge. any ideas on cause or a fix would be much appreciated.
FPV 204 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2007, 09:24 PM   #7
BFGT40
Smells like burnt rubber
BFGT40's Avatar
Who's adaptor are you using to interface the DVD to the ICC?
BFGT40 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 01:32 PM   #8
FADI75
Sponsor
hi
if you done the complete conversion with us please call us with the invoice number so we can assist you with your query.
cheers
fadi75
Old 27-08-2007, 01:45 PM   #9
FADI75
Sponsor
Thanks Guys!
Chris.
chris
if you think i am not doing a good job on the forums please do report it to the right party.
Thanks
fadi75
Old 27-08-2007, 02:12 PM   #10
FADI75
Sponsor
hi
we do have the RGB Convertor kits complete with the Boss DVD players $720.00
cheers
fadi75
Old 27-08-2007, 03:26 PM   #11
FADI75
Sponsor
Hi Guys,
  • How much?
Thanks!
Chris.
Chris
please see answers below
Hi Guys,
1-2 volt peak-to-peakI gather there are 3 sets (Front, Rear, Sub?)
You can have up 2 five RCA’s-2 Front, 2 Rear and if your car currently has a Subwoofer we can add this line also.What do you use for a trigger for an amp? (there is a mention on your site about this)
A circuit we place in unitAny problems with noise etc, or does it just act like any other H/U with RCA outputs?
We have never had a complaint about noise.Any other info you can provide?
That’s about it.
How much?
$220
Thanks!
Chris.
Old 28-08-2007, 07:53 PM   #12
[dave]
how much would it cost to post the icc from 5110 to where eva u are in melbourne
[dave] is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2007, 08:16 AM   #13
FADI75
Sponsor
dave
you have to check with your courier.
cheers
fadi75
Old 29-08-2007, 06:47 PM   #14
[dave]
just wondering do you have to already have a sub for you too be able to add rca's input's
as i have the basic icc and want to add front inputs and a sub input
Old 30-08-2007, 08:31 AM   #15
FADI75
Sponsor
dave
please call us to discuss 0397991444
cheers
fadi75
Old 30-08-2007, 06:33 PM   #16
FPV 204
Shockwave
FPV 204's Avatar
Originally Posted by FADI75
hi
cheers
fadi75
Yeah Fadi done by you guys. i am using the Alpine Vehicle Hub been working fine for 12months only had problem since low level outputs fitted.
Just posted here to put the feelers out to see if anybody else has had similar problem. Been going to call you to discus but been flat out at work.
