06-03-2007, 04:37 PM | #1 | ||
Hi, my first post so go easy on me...
This is a simple job I thought but I can not for the life in me remove the fuel send unit fitted to the tank on my 1968 MK2 Cortina. The sender is positoned on the LHS of the tank, and it looks like it only requires rotating to remove, but it will not budge. Can someone please help as I do not want to use extreme force for this job to prevent damaging anything. Is there something I should know? I have a repacement send to put in, to fix my fuel guage faults, as I susspect the sender float is buggered.. Thanks in advance.. Radar |
06-03-2007, 04:44 PM | #2 | ||
PM me if you want
I used a fair amount of force i recall when i changed the tank on my cortina as it had a leak at the filler neck, I had to rotate it the left from memory. I could check my gregorys tonight.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
