it is pin 45 on the ECU pink with a blue trace or pin 16 on the cluster where it is bink with a white trace not sure where the connector is where it changes colour but it does these colours are for AU2 but i assume it suits all
drive it like u stole it
thanks mate, im trying to wire up a shift light so i will probably just try and use the wire that goes into the cluster. I no there is 2 plugs that go into the cluster which one of these would the wire be in? also do you no which pin power and earth is out of all the wires that go into the bak of the cluster?
www.aufalcon.com/phibza |
would anyone know how to remove the cover to the traction control button to change the globe and the power windows cover thanks
russellw great diagrams, was wondering if you have a schematic that covers the Oxy Sensor to the ECU, keep up the good work....I,m doing a project car that i'm installing the oxysensor in, have the ECU and fuel/air mixture gauge etc
#5 | |||
Chairman & Administrator
![]() ![]() Join Date: Dec 2004
Cheers Russ
Observatio Facta Rotae
#6 | |||
Regards |
hey russell, i got au I fairlane.... double din premium sound setero with the 6cd stacker in the boot. Was wondering if you have the diagrams and legend for all the wires at the back of the head unit ie. which wire does what? there is two different plugs at the back as well as the antenna. Im putting a dvd screen in and would be great if i know what the wires all mean coming from the loom.
thanks |
You will need to look up the connector number and then look up the connector seperately in the connector diagrams - this should show you all the wirs and the master diagram will show you the actual assignments.
Cheers Russ
thanks buddy got it all under control now thanks alot, great diagrams
alex |
FishermanDan
Is there underhood wiring diagram for sensors to ecu pin numbers ie cam angle, knock, T-map & ign coil pak?
#11 | |||
Click on the link to Technical Resources on the menu bar above and then look under Technical Documents. Cheers Russ
#12 | ||
thnaks was very helpful, ui have installed the dvd and the dvd radio adn tv all works i jsut cant get the soubnd to come out of the speakers.. any thing i may be doing wrong??
and the blue cord coming from the dvd saying back is not connected to anythin maybe this has something to do with it but everythin else is working |
Does anyone no if there is possibly a AUX port at the back of the Stock CD player/radio in the AU Fairmont?
Egotism is the anesthetic that dulls the pain of stupidity
#14 | ||
Hi can someone help
My aircon fan in the dash of my AU Fairmont Series 1 has gone troppo and only works on H which is flat out if I try 1 2 3 4 5 6 7 8 or9 I get no air at all only air on H any ideas thanks JOHN in Brisbane also looking for a rear wing in Mercury silver for my BA Ghia thanks |
#15 | ||
so google sent me to this link when searching for au falcon wiring info,
so will post on this old old thread. the wiring shown on this link for au falcon http://www.fordforums.com.au/vbporta...?articleid=688 it shows the pcm/ecm connector info, I have au1 1999 model, and colours are different to that shown. so assume that shown is for au2 or au3 if anyone requires correct colours for au1 drop me a message |
#16 | ||
have modified pcm wiring pinout for au1 falcon, it has two extra wires not yet established what they are for at pins 7 and 44. Colours for au1 that are different to au2 and 3 shown also.
had to split into 4 pics to upload, you can cut/paste them into one pic tried to upload as one pic but to get the min file size ( 147kb) none of the writing was readable. |
Thread Tools | |
Display Modes | |
