Hi all,
Does anyone know where I can purchase a new set of gear lever bushes to suit a 1993 KH Laser 5 speed manual? They are mounted on the outside end of the gear lever. Cheers, David. |
Hi David,
If you are talking about the ones at the bottom of the lever, they are also the same as the ones on the linkage that is at the other end of the lever as well. Part number B001 46062 99 still available from Ford. There is also another bush that runs at the end of the other linkage that runs from the square part around the gear lever, it has a part number of GJ21 46041 and is still available from Ford also. |
Thanks for your help GTLEGEND.
I honestly didn't think you could still get these parts from Ford anymore. Cheers. |
Shakern, not stirred
These should also fit. Capri and Laser essentially the same motor and gearbox. We used a Laser service manual to figure out how to replace the bushes.
http://www.ebay.com.au/itm/FORD-CAPR...gAAOSwJQdXBN4G |
#5 | |||
The small blue bushes in the picture are the same as the KF/H laser, B001 46062 99 (what KH323 needs), but the bigger rubber bush in the top middle of the picture for Capri is the same as the earlier KC/E Laser, not the KF/H style. The Capri/KC/E rubber has part number B092 46041 where the KF/H has GJ21 46041. Not sure about the other parts in the kit.. |
