Hi all;
I have a series 1 ford forte ( 56000Kms ) that i want to install a 12 Volt socket ( merrit type ) so as i can run a 40 ltr engle fridge that will sit on the back seat of the car. Ok looking at the owners manual there are a couple of spair fuses ( 1&2 ) in the fuse pannel under the drivers right foot, and are these fuses switched off with the Ingnition. Question is, is there a negitive post near the fuse pannel or am i better of to just use the chassie as a earth point. Just thought i would ask before i go in boots and all. |
There is an earth point at one end of the earth panel but it will depend where you end up mounting the socket as to whether it is better to use a chassis earth or not.
Cheers Russ
Hi all & thanks Russ;
I will end up placeing the power socket at the back of the centre console or inside the console under the arm rest. Will have to work out the easyest way. I will be useing a length of 6mm low voltage wire left over from my caravan when i installed a few 12 sockets around the van. Being a semi retired electronics teck i was allways told to run a power and earth wire back to the fuse pannel and earthing there.Even in some cases the power feed was taken all the way back to the main battery (s). I've seen to many problems because of a poor earth, audio amplifiers and 2 way radio trancievers were one thing that comes to mind. |
#4 | |||
