ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link |
28-08-2012, 09:57 PM | #1 | ||
FG XR50 TURBO
today i pulled out the icc to fit a overlay touchscreen, refitted the icc, security code came on the screen,
with the ignition off i pressed the volume button nothing turned the car on [starts ok] still no response from all the buttons on the entire icc, the icc screen lights up though. |
28-08-2012, 10:21 PM | #2 | ||
Have you pressed the volume button with the ignition on?
28-08-2012, 10:24 PM | #3 | ||
FG XR50 TURBO
hey done that still nothing
28-08-2012, 10:32 PM | #4 | ||
There's no code, are you sure it's back together correctly and it's seated back in the plug and socket at the rear correctly?
Pull it out again and make sure the socket attached to the car is pulled all the way out before reseating the ICC.
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan |
28-08-2012, 10:41 PM | #5 | ||
FG XR50 TURBO
the big white plug at the back, how do you pull it foward to hear a click, i've tried pulling it outward nothng is there a special way to pull it foward??
does it matter which plug i pull out first [the 5x plugs under the icc?? |
28-08-2012, 10:45 PM | #6 | ||
Yes it matter which ones- if the battery is still connected. If the wring plug is pulled first with the battery connected you can damage that
28-08-2012, 10:49 PM | #7 | ||
FG XR50 TURBO
damage what?? and yes the battery was still connected when i pulled the plugs out
28-08-2012, 10:53 PM | #8 | ||
From memory the plugs are removed right to left and connected in the reverse.
And as mentioned, the order is important. Did you hear lots of relay clicking when you were unplugging the plugs?
28-08-2012, 10:58 PM | #9 | ||
FG XR50 TURBO
i'll have another go tomorrow if all else fails, i'll just take it to asl to get them to have a look??
28-08-2012, 11:05 PM | #10 | |||
Current Rides: 2017 Ford Mustang 2020 Ford Everest Sport Past Rides: 2017 Kia Stinger GT 2008 FG XR6 Sedan 2008 FG G6E Sedan 2004 BA XR8 Sedan 2008 BF XR6 Turbo Sedan 2004 BA XR8 Sedan 2003 BA XR8 Ute 2003 BA XR6 Sedan Last edited by Cashie; 28-08-2012 at 11:11 PM. |
28-08-2012, 11:05 PM | #11 | ||
FG XR50 TURBO
Did you hear lots of relay clicking when you were unplugging the plugs? __________________only when i connected the second one from left [black] first then soon as i connected the first from left [white] the clicking stop.. have i damaged the icc?? or a relay |
28-08-2012, 11:08 PM | #12 | ||
http://www.fordforums.com.au/vbporta...article&id=182
And I ask again, did you put the ICC back together correctly?
28-08-2012, 11:14 PM | #13 | ||
FG XR50 TURBO
thanks cashie i've read that post early before
28-08-2012, 11:17 PM | #14 | |||
I thought it covered it all pretty well?
28-08-2012, 11:49 PM | #15 | ||
FG XR50 TURBO
yes it does but for the life of me i can't to seam to pull the white connector foward to hear a audible click
29-08-2012, 12:41 AM | #16 | ||
ORSM Ford Cruisers
2004 Harvest Green XR6 Orsm Ford Cruisers ORSM Ford Cruiser's Web Site Contact me for all your Cluster Programming/Repairs & Window switch/ICC colour change for BA/BF/FG Falcons & Territory. Visit my SITE for info. |
29-08-2012, 08:45 AM | #17 | ||
FG XR50 TURBO
you are a legend aumatt, that video makes more sense now
29-08-2012, 09:05 AM | #18 | ||
FG XR50 TURBO
i had a second look at the video it seams that the white plug in my car is fully out so what could it be?? would i cause something when i unpluged the 5x plugs in different sequence
29-08-2012, 10:21 AM | #19 | |||
Sponsor
check if you havent damaged any of the pins on the connectors while sliding ICC in and out, sometimes due to removal and refit pins get bent or broken cheers fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS AUTHORISED FORD REPAIR CENTRE website: www.aslautomedia.com.au email: info@aslautomedia.com AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN |
29-08-2012, 10:30 AM | #20 | ||
FG XR50 TURBO
hey fadi, i'll have a look this morning if not, can i bring it today for you guys to a look?? cheers dean
29-08-2012, 11:04 AM | #21 | |||
Sponsor
we can have a look tomorrow no problem cheers fadi75
29-08-2012, 11:14 AM | #22 | ||
FG XR50 TURBO
thanks fadi, but my car is booked in to herrods for next 2 days
i'll give you a call next week if i can have a half a day off from work. |
16-07-2014, 04:56 PM | #23 | |||
20-08-2014, 11:39 AM | #24 | |||
Please help |
12-03-2016, 01:58 PM | #25 | ||
hmmmm boost
Searching for an answer to this problem there is not much that is mentioned on what resolves the issue, today I did a job where i needed to replace a faulty ICC, and once i fitted the new unit i got the "CODE" come up on the screen, long story short, the bottom right bolt that holds the ICC unit to the car is an earth point, and once i screwed the bolt in the "CODE" went away, just thought this info would be useful for someone in the future.
Daily Driver - EB Fairmont Wagon, 347, Cardinal Red. The Toy - 94 ED XR6 5spd, Pearl Black, 253rwkw of boosted goodness.
29-05-2016, 12:37 PM | #26 | ||
Typhute Designer & Owner
THANK YOU SEXYR6, My problem answered!!! Legend.
Now to go and try. Bj |
