Old 31-07-2012, 09:07 PM   #1
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Default Brake Vacume Line
Hi All
I Have A V6 Gt Capri . And I Pulled Of A Fuel Line Of My Brake Vacume ...from The Booster .
Just Out Of Mind Are They Just About The Same Brake And Vacume Line
WOGBOY69 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 09:31 PM   #2
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Default Re: Brake Vacume Line
Wogboy, you're gonna have to be a bit more specific about what you're asking here if you want any responses from the forum. No offense mate - but your question does not make any sense to me.
Cheers!
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2012, 10:57 AM   #3
JimStone
Originally Posted by WOGBOY69
Hi All
OK, using my trusty Phantom decoder ring...
Hi all,
I am the proud owner of a V6 GT Capri. Some chap has fitted fuel hose between the manifold and brake booster at some stage in the past.
Is this OK or do I need to replace it with brake vacuum hose?
It can be done in a pinch to get you out of a bind, but I would recommend using brake vacuum hose for long term peace of mind; brake vacuum hose tends to remain pliable, not harden and crack like fuel line. From memory the correct brake vacuum hose will be 11/16ths and can be secured readily from any brake specialsts.
JimStone is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2012, 01:21 PM   #4
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
thats a big bore vacuum hose jim,
mine had 11/32" vacuum hose, you can sometimes fit the 3/8" (9.5mm) stuff too.
usually marked 11/32 VL DOT on the hose too.
it is thicker walled hose than fuel line, some of it is also double reinforced.
most brake places, and some auto parts shops have it in stock,
buy it by the foot, approx $6 p/f last time i bought some
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2012, 04:34 PM   #5
allanv6gt
Tippy-tronic Free Zone
Yep, double reinforced to withstand the vacuum suction and stop it collapsing on itself.
allanv6gt is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2012, 08:25 PM   #6
WOGBOY69
WOGBOY69
WOGBOY69's Avatar
Hi All
Thanks For All The Replys Back..
All I Was Stating Was . On The Car Right Now On My Brake Booster I Have Fuel Hose Going To The Booster And Manafoild .
All Iam Stating Thats Not The Right Line To Use Ofcourse .
What Are The Bad Things That Could Happen Ussing A Fuel Hose Instead Of A Brake Vacume Hose ..
Sorry For Being Thick For Some . On Understanding Me ....
Old 01-08-2012, 10:43 PM   #7
JimStone
My bad, you are correct - 11/32 is the right number, don't know how I managed to write 11/16
Bad things - well, fuel line may collapse under high vacuum and will harden and crack over time: both will lead to loss of brake pedal assistance.
James
