17-04-2012, 10:18 PM | #1 | ||
Has anyone got a template which to put on the firewall to drill out the new 4 holes to mount the booster. Have tried but didn't get it quite right and have buggered the booster.
If there is anyone out there you are my only hope! Robert |
18-04-2012, 11:27 AM | #2 | ||
You could use a series 2/3 pedal box and take a template off that.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
18-04-2012, 07:55 PM | #3 | ||
did that, thanks for the help. Did you do this conversion and have trouble with the booster hitting one of the bolts on the steering column.
18-04-2012, 08:39 PM | #4 | ||
No I haven't done this but I found out the difference when using a series 1 pedal box in a series 3 for my manual conversion. I ended up drilling the holes I need in the pedal box and it was all good I hope you can get around the bolt hitting the steering column.
Toy Car Build |
19-04-2012, 01:11 PM | #5 | ||
the bolt wasn't hitting the sterring column but the body of the brake booster. Just got it all together after all the mucking around. I just hope the way my brakes felt without changing the booster and master cylinder is not indicitave of this conversion, mine were downright dangerous. Thanks for help.
