06-11-2011, 05:23 PM | #1 | ||
Got a stock 1.6 two door coupe and have an rs2000 sway bar. Only difference I can see is that the exhaust mounting centre box that the bush would bolt through on an rs appears welded?
Has anyone ever fitted one? Do you just cut off the old mount and then weld a bolt on? Ideas appreciated. |
06-11-2011, 10:33 PM | #2 | ||
Can you post a pic of the mount?
12-11-2011, 06:21 AM | #3 | ||
The RS (2lts) have an extended exhaust mount which comes off the swaybar chassis mount. Is basically a threaded tube that tapers to pick up the rubber exhaust hanger.
