02-05-2010, 11:51 PM | #31 | |||
not sure if its the angle of the picture but that left spring doesnt look like its in there correctly (shock looks too far forward)
i doubt theres anything with it, im most likely seeing things :P
Daily: 2003 BA Fairmont Ghia - Mercury Silver | Sunroof | Tint | XR6T 3.46 LSD Project: 2001 AU II Fairmont Silhouette | Optioned 17" Tickford wheels + Sports suspension | Tint Weekender: 1989 NA II Fairlane - Rosewood | Standard (with functioning SLS!) Quote:
03-05-2010, 12:38 AM | #32 | |||
2mny projects 2 lttl time
Yet the damage is on the driver's side isn't it? [/QUOTE] Last edited by kcej; 03-05-2010 at 12:45 AM. |
03-05-2010, 08:31 AM | #33 | |||||
Stroking it...
And yes, the damage is on the drivers side.. It started off as a slight clunk over harsh bumps and developed into a big bang over all bumps... The roads around me are dodgy as, so it's pretty damn annoying..
Had: 347ci AU Then: Now: Busted assed EB Wagon - 5sp and Dual Fuel. |
03-05-2010, 08:48 AM | #34 | ||
they call me Tibbo
check to see if the arms are in the same hole, side to side
the xr arms are slightly shorter/longer (can't remember) to fix the angle of the diff for the lower setup. 2 things have happened imho: they are not in the same holes, fouling the geometery or you have one standard arm vs one xr arm
03-05-2010, 09:19 AM | #35 | ||
Petro-sexual
For Tickford suspension vehicles (EL & AU) the arms should be 340mm between centres and should have the kink in them to clear the diff, they should be located in the rear most hole on the diff.
For standard suspension (EL & AU) the arms should be 320mm between centres and are straight, they should be mounted in the front hole on the diff. XE-EF rear suspension upper arms are 340mm between centres, but they dont have a kink in them, the diffs in these vehicles were never supplied with a different mounting point. |
03-05-2010, 10:39 AM | #36 | |||
they call me Tibbo
03-05-2010, 11:18 AM | #37 | ||
Petro-sexual
All Nolothane documents refer to 'std' and 'Tickford' height. They dont mention if they are kinked or not though.
http://www.nolathane.com.au/bulletins/Update%200303.pdf |
03-05-2010, 11:23 AM | #38 | |||
they call me Tibbo
03-05-2010, 11:31 AM | #39 | ||
Petro-sexual
Ahh, no worries. I know for certain the 320mm EL upper arms are straight, I just assumed AU was the same as there's no need for the kink at std height.
04-05-2010, 12:18 AM | #40 | ||
AU II XR8
Did the knocking occure while just driving along the road, or slowing down/speeding up?
AU XR8 II ute XD FAIRMONT GHIA 302 XA FAIRMONT 302 TOPLOADER |
04-05-2010, 10:29 AM | #41 | ||
So does it have bump stops fitted ?
04-05-2010, 03:51 PM | #42 | ||
The Monty
wheel bearings?
04-05-2010, 04:13 PM | #43 | ||
Stroking it...
Some interesting reading here guys..Really appreciate the help.
I've been pretty crook so not had a chance to look at the car, but will do over the next couple of days. Got a good list of things to check!
04-05-2010, 04:15 PM | #44 | |||
Stroking it...
04-05-2010, 07:06 PM | #45 | ||
was it a factory live axle as i thought all GHIA'S were independant espesally v8 ones. if the conversion to live was done later it would explain how the wrong upper or lower arms could have been used. there is WAY to much impact to be play in bushes or shocks(which control rebound). as i said in the original thread it may have had very, very low shocks in it before
04-05-2010, 07:13 PM | #46 | ||
Stroking it...
Indeed they were, she's actually only a monty, not a GHIA.
05-05-2010, 09:21 PM | #47 | ||
I'll add to the recommendation to go and speak to Greg at City Suspension, he did all the work on my old AU. He's a good bloke, been around for a long time and calls a spade a spade.
Good luck with it, at least you've found the problem now. Cheers, Matt. |
05-05-2010, 09:34 PM | #48 | ||
Stroking it...
Thanks Matt, I have had another recommendation for Greg as well, looks like a goer!
Will give him a call this week
13-05-2010, 09:21 PM | #49 | ||
The only thing u'll see!!
Mate, looking at your pictures i can't believe that no one else could see what is acctually happening, So as Per USUAL Taxi mechanic to the rescue!
Where the rear upper arms bolt to the diff housing, their are three holes, who ever installed your upper arms, installed them in the incorrect hole. THE GUARRANTEED FIX: Install new upper arms, (old ones damaged) and this time install the bolts through the upper rear hole in the housing, not the lower rear hole. If is wasn't illegall id be telling everyone here what i really think. LATER...................... |
14-05-2010, 09:51 AM | #50 | |||||
they call me Tibbo
14-05-2010, 11:20 AM | #51 | ||
Stroking it...
Me and The Monty are checking it out this weekend, I've been flat out with work, and crook, so had not time to look at the car.
Will report back! I REALLY hope its just in the wrong hole....that sounds wrong...
14-05-2010, 01:02 PM | #52 | ||
Just slidin'
If it were in the wrong holes, and the correct trailing arms were used, as you have stated, Mr AU turbo the diff would be on an extremely odd angle, and the tailshaft obviously so, creating large amounts of vibrations and rendering the car basically undriveable. Now, before you get your panties in a knot, Im not saying your completely wrong, but you were on the right trail, as others have pointed out, seeing as they read the thread in its entirety. The problem you have described would have happened if the wrong trailing arms were in the correct holes, being too long an arm in the correct hole, meaning it has bent to give itself some leverage. I think that what Tibbo said to begin with will be on the money. Instead of calling us fools, or in your language, FEWLS, maybe you could show some decency and apologise to everyone, or you should maybe just go back under the rock where you came from, and not bother with the forums, you obviously know everything being a race car builder/taxi mechanic, so there is no reason for you to be here?
MD Mondeo - For the family
NP Pajero - For the adventure |
14-05-2010, 09:07 PM | #53 | ||
To the Monty, I agree with the last part of the post, too many beers and too late at night, once i reread what id written about 5 mins ago, i too was in shock. So i agree.
And appologise. Im running the standard shorter arms mounted further forward, however my Au isn't quiet as low. Super lows really are too low on most cars, not just falcons. |
14-05-2010, 09:23 PM | #54 | ||
Stroking it...
Thanks Auturbo6, your trolling comments that night were not appreciated by many, maybe beer and forums dont mix :P
The Monty will be over sometime over the weekend and we'll get a new arm and install it, fingers crossed! Then after a tune to sort out some auto shifting probpems, and new rubber, she's for sale.. :(
14-05-2010, 09:27 PM | #55 | |||
Flairs - Truckers Delight
15-05-2010, 06:04 AM | #56 | ||
Just slidin'
Dont worry, Ive copped many as well. Shift work, plus no sleep, and I flip sometimes, get home from work and wish there was an edit button.
16-05-2010, 02:10 PM | #57 | ||
Just slidin'
So Cam, what was the verdict.................
16-05-2010, 02:32 PM | #58 | ||
Stroking it...
16-05-2010, 04:30 PM | #59 | ||
Stroking it...
By the way, thanks to all those that helped, greatly appreciated!
