Old 14-06-2006, 08:50 PM   #1
Aussie_Escort
Aussie_Escort's Avatar
Default Vinyl Roofs
Hey,
Did vinyl roofs come standard on Mk2 Escort Ghia's?
How do you remove the vinyl?
And is there a way of telling if there is rust underneath it, without removing the vinyl?
Cheers,
Aussie_Escort
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 09:16 PM   #2
JamesR
not sure about removing it.
but i think you can see the rust under it cos the rust bubbles up.
is there anyway to water proof it? i wanna respray mine as well..
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2006, 09:10 PM   #3
Aussie_Escort
James, not sure bout waterproofing the vinyl but it's pretty expensive to do a respray.
Anyone know how to go about removing vinyl roofs?
Cheers,
Aussie_Escort
Old 25-06-2006, 06:36 PM   #4
AusCaRnAgEr
1982 Ford XE Falcon 351
With the vinyl roofs, is it primed metal underneath or is it painted like the rest of the car?
AusCaRnAgEr is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2006, 08:33 PM   #5
revcore
revcore's Avatar
I removed the vinyl roof from my old TE Cortina and it was painted the same as the rest of the car. The roof was rust free so it was just a case of ripping it off then rubbing the hardened glue from the roof with a sander. It was then taken to the spray booth for a full roof respray. The end result was 100 times better that the terrible old vinyl rubbish.
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2006, 08:50 PM   #6
Aussie_Escort
revcore - So there were no problems with removing the vinyl? Stupid question I know but is your roof straight? I've heard that the effort in getting the glue of the roof can cause it to buckle and it’s a pain getting it straight again?:
Cheers,
Aussie_Escort
Old 27-06-2006, 11:40 PM   #7
holeshot
holeshot's Avatar
to remove it you need to use something to soften the glue as you pull it
back.prep solvent would do but Tolulene would be better.
one word with tolulene is wear a respirator and use it outdoors,as it is
carsnogenic.
to water proof, use some vinyl protector(non silicon base).
armoral is a spray painters worst nightmare
holeshot is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2006, 07:14 PM   #8
revcore
revcore's Avatar
Cheers,
Aussie_Escort
When the vinyl was removed it was fairly straight forward but there was a few tricky bits like where the windscreen rubber overlaps the vinyl (The same with the rear window too) but we ended up removing the front and rear glass and rubber which would have needed to be done anyway when the roof was resprayed. Regarding the glue and the roof buckles, I didn't encounter such problems....I'm guessing that was due to the fact that the car had been kept undercover both by me and the original owner so it didn't endure the elements as much as other vinyl roofs.
My Ride...
Old 29-06-2006, 10:17 PM   #9
Aussie_Escort
Cheers for the input and tips guys.
I think i'll be removing the vinyl but maybe I should get a pro to do it.
Once again cheers guys!!
Cheers,
Aussie_Escort
Thread Tools
Display Modes
